Oregon roof rasiers Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2010 » January 2010 » Oregon roof rasiers « Previous Next »
Tony Rian (Rianrts)
Username: Rianrts
Post Number: 50
Posted From: 76.115.134.90
Posted on Saturday, January 23, 2010 - 12:57 pm:
Are there any experienced roof and cap installer's around????? I lice in Eugene and want to get started on my 2nd bus this time its and Eagle and I want to raise the roof and put new caps on. Thank Tony
Post Number: 1328
Posted From: 24.239.5.12
Posted on Sunday, January 24, 2010 - 9:56 am:
Hi Tony,
Contact:
Southern Oregon Diesel
David Gregory
Roseburg
541.672.7400
800.755.7634
He's a conversion friendly guy who co-hosts the Busin' USA events. He may not actually do raises, but he will be able to point you in the right direction.
Username: Luvrbus
Post Number: 837
Posted From: 74.32.95.26
Posted on Sunday, January 24, 2010 - 10:27 am:
Tony, Paridise Coach in Coberge OR talk to Larry. Richard at R&M in Turner should know of some also 1-800-350-1656.But I would go with Larry IMHO ? what model Eagle
good luck
(Message edited by Luvrbus on January 24, 2010)
Tony Rian (Rianrts)
Username: Rianrts
Post Number: 51
Posted on Sunday, January 24, 2010 - 12:43 pm:
I have a model 19 from N.J. Thanks for the info.
Username: Luvrbus
Post Number: 838
Posted on Sunday, January 24, 2010 - 1:08 pm:
Tony, the model 20 is a great bus you will need help on the back it gets a little tricky there are you going to keep the bus AC located in the rear cap.
good luck
Tony Rian (Rianrts)
Username: Rianrts
Post Number: 52
Posted on Sunday, January 24, 2010 - 5:30 pm:
Nope the ac was gone when i got her. The front window on the cap is also starting to come out also. Generaly how much does everyone raise there roofs??? I alomst think i want to go smooth roof but not sure. If I place roof airs then I want to duct them the length of the bus. I know that eagle's are great for slide out but that seems very expensive for what you get. Any comments or suggestions are great and welcome.
larry currier (Larryc)
Username: Larryc
Post Number: 308
Posted From: 64.40.60.17
Posted on Monday, January 25, 2010 - 6:29 pm:
Measure a stock Model 10 cap and see how many inches that cap will raise your roof. With your tall windshields I think it works out about right.
The front window is just a piece of glass that has a bolt on each side. Tighten the bolts, see if that solves the problem.
R&M makes an exact blank with no cutouts that looks nice for the rear. Keeps the newer coach look.
Bob at Infinity installed one on one of his personal shop coachs a couple of years ago, looked great on an older coach.
I don't know of anyone that mass manufactures a front cap for the 20 unless you raise the roof and use a 10 cap. That has been done, maybe one of those guys will tell you how many inches it took to absorb the tall glass and make it all look like a stock 10 from the front.
Username: Luvrbus
Post Number: 840
Posted on Monday, January 25, 2010 - 7:22 pm:
You install a model 15 cap on the front with a 8 inch raise.
good luck
Arthur J Griffith (Arthurseagle)
Username: Arthurseagle
Post Number: 71
Posted From: 72.236.102.217
Posted on Tuesday, January 26, 2010 - 12:36 pm:
Luvrbus - I don't think a 15 cap will work on a 20. The 15 cap tapers from a 102" body to 96"
going forward. I believe that the 20 bus has a
96" body with mo 15 windshields in place. I believe that the 10 cap is more apt to fit. The caps that come from R & M can be ordered with a
lot of extra tail to accomplish just about any
height of roof raise. Happy Bussing everyone.
ARTHUR
Username: Luvrbus
Post Number: 843
Posted From: 74.32.83.4
Posted on Thursday, January 28, 2010 - 8:37 am:
Arthur, the 15 cap is 96 in I have a 15 cap on my 05
good luck
