Air tank Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2010 » February 2010 » Air tank « Previous Next »
Douglas Wotring (Tekebird)
Username: Tekebird
Post Number: 421
Posted From: 71.57.224.23
Posted on Saturday, February 13, 2010 - 5:03 pm:
what do you suppose the max air pressure an MCI Air tank will take
found a new tank 25"x 7.5" which I think would fit nicely under my enclosed motorcycle trailer for "shop air" when away from home/the coach
Patrick levenson (Zubzub)
Username: Zubzub
Post Number: 151
Posted From: 174.91.229.84
Posted on Saturday, February 13, 2010 - 5:16 pm:
Most truck air systems have safety valve pop offs set between 125 PSI and 225 (that's what the aftermarket pop offs adjust to). Given that most air lines are rated for 250 while usually carrying 125, I would guess an MCI tank would have no trouble with 125-150. If you want to supercharge it (250) for more reserve you might get in trouble.
Just guessing here, all pure conjecture and a bad cold talking.
Post Number: 1801
Posted From: 76.71.100.208
Posted on Monday, February 15, 2010 - 11:03 am:
How high can your shop compressor pump?
The attachments will rupture long before the tank will.
Somewhere in the dark recesses of my head, 300 lbs is bobbing in the flotsam?
You'd need to ask a tank manufacturer, or perhaps a Bendix rep, the coach folks won't know.
Username: Zubzub
Post Number: 152
Posted on Monday, February 15, 2010 - 11:40 am:
Oh yeah I just remembered that scuba tanks are the way to go for high pressure.
Dale Waller (Happycampersrus)
Username: Happycampersrus
Post Number: 369
Posted From: 166.225.52.152
Posted on Monday, February 15, 2010 - 2:46 pm:
I drag race motorcycles on the weekends and use nitrogen for tires and air shifter.
Go to a welding supply and get a "90" bottle (scuba tank size)and a regulator. They are charged to 2500lbs or so and last a long time. Tank refills are around $20 bucks
Post Number: 1802
Posted From: 76.68.133.200
Posted on Tuesday, February 16, 2010 - 9:06 am:
BBQ tanks are another source for a poor man's air pig.
