House Battery Bay Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2010 » March 2010 » House Battery Bay « Previous Next »
Jim Wilkerson (Wagwar)
Username: Wagwar
Post Number: 32
Posted From: 12.158.159.62
Posted on Thursday, February 25, 2010 - 2:57 pm:
I'm looking at a bus that has a house bank of 6 8D batteries. The batt bank is on a slide in the center bay of an MC9. In the same bay, somewhat separated by wall panels, but certainly not isolated (however there is a lot of air space above the batteries) is a basement A/C unit and inverter. Is it OK for those components to share the same bay? Is that asking for trouble?
Thanks!
clint hunter (Truthhunter)
Username: Truthhunter
Post Number: 609
Posted From: 24.129.238.13
Posted on Thursday, February 25, 2010 - 3:39 pm:
...flooded lead batteries give off hydrogen & must be atmospherically vented separately from any source of the ignition (Hydrogen is lighter than air), the "acid fumes" are also not a good thing and are corrosive. Some batteries have a vent tube to connect a hose for venting and glass mats normally do very little venting, but it must be addressed to prevent hydrogen explosions.
-also of concern is the heat created from the utilities should be insulated from the batteries as the charging rate is also limited by temperature, depending on type of battery.
+6 8Ds in the middle bay is 1,000 lbs of weight in the least ideal place, near the drive axle is best ; near the front axle is ok if other weight such as the factory AC condenser & evaporator has been removed; but one must factor in the conversion modifications & how it will typically be loaded when used to decide on this criteria.
Username: Wagwar
Post Number: 33
Posted on Thursday, February 25, 2010 - 3:50 pm:
Would boxing the batteries and venting the box be an acceptable solution if moving the bank is not feasible?
Post Number: 612
Posted on Saturday, February 27, 2010 - 8:49 pm:
gas-tight separated from any spark source such as electrical conductors/switches or appliances (think accident safety) , perhaps you can do it simply where they are now, but inspect and you'll begin to know. venting must be higher than the source of emission, add lower vents as well, if you wish to get heat ventilation using free existing convection
larry currier (Larryc)
Username: Larryc
Post Number: 312
Posted From: 64.40.60.237
Posted on Sunday, February 28, 2010 - 11:02 pm:
I would move the inverter. Seems like they always give off a big spark when I hook/unhook them.
You don't really want the AC to suck from that compartment, hopefully it ducts out for fresh air.
Inverters are pretty happy in water bays where it stays cool. Mine are mounted on large pieces of aluminum for fast heat dissapation and sit on the water tanks. Even in extreme heat I have not had one shut down.
Post Number: 1145
Posted From: 75.245.107.30
Posted on Monday, March 01, 2010 - 9:45 pm:
Why, normally, would one need to "hook/unhook" an inverter? (And wouldn't one normally "unhook the batteries" first?)
Just curiosity...not criticism...:-)
Username: Jackconrad
Post Number: 1240
Posted From: 74.4.63.215
Posted on Tuesday, March 02, 2010 - 9:35 am:
Only time I "hook/unhook" batteries or inverter is when doing repair (inverter) or maintainence (batteries). Jack
Post Number: 1149
Posted From: 75.242.222.188
Posted on Tuesday, March 02, 2010 - 10:29 pm:
Me 2, Jack...:-)
