Post Number: 121 Registered: 10-2004 Posted From: 24.63.8.181
![](http://www.busnut.com/bbs/messages/thumbnails/16465.jpg)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, February 28, 2010 - 3:03 pm: | |
Well they say pics are worht a thousand words so I am posting the pics of my newely installed combination gray and black "D" box. I will be putting a large 80-100 gal tank in the front compartment. the "D" box will be pumped into this tank when I am dry camping via a macerating pump from the 3" fitting in the front of the "D" box. When I am at a campground I will just dump out the 3" fpt on the back of the box.And because I have to agree with the guy with the 5 or 6 ac's on his roof It could be unsavory to mix a whif of #$@* while eating craks and cheese so I will be venting both the "D" box and the large tank out the opposite site of the bus and I am thinking, not done brainstorming the system yet but I think the 2" pipe is going to go out a hole in the side of the bus and 10' up the side with the pipe being removable and stowed on the rocker panel I will post the pics of the tank install in the FB section. http://busnut.ning.com/photo/photo/listForContributor?screenName=0kg5416dco3he |
Post Number: 364 Registered: 9-2007 Posted From: 24.183.21.246
![](http://www.busnut.com/bbs/messages/thumbnails/18997.jpg)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 01, 2010 - 11:20 am: | |
Nice looking plumbing Doug, how did you end up attaching the fittings? Epoxy or plastic weld or what? John |
Post Number: 123 Registered: 10-2004 Posted From: 24.63.8.181
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 01, 2010 - 4:57 pm: | |
Hey J&B I used pvc pipe and glued with pvc cement.The grommets going into the tank are to cool just cut the hole and insert the pipe the grommet seals it. |
