Post Number: 499 Registered: 10-2003 Posted From: 74.244.14.221
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 07, 2010 - 7:11 pm: | |
Busnuts I need an opinion. I have noticed for the last few hundred miles a rythmic squeak or rubbing soud coming from somewhere in the passenger front wheel area. I thought maybe I had a shoe dragging or maybe a bearing getting flakey but when I jack it up the wheel spins freely with no noise. Could this be a sign that a bearing is getting worn but doesn't make noise without the weight on the wheel??? Curious as to your experiences as this is the first heavy piece of equipment I have had to troubleshoot. Tim |
Post Number: 1861 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 07, 2010 - 7:48 pm: | |
You could have a wheel bearing getting dry, or starting to go bad. Pull wheel, check bearings and adjustment and also check brake lining and shoe return springs. Of course it may be just about anything else too. |
Post Number: 234 Registered: 10-2006 Posted From: 99.23.137.192
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 08, 2010 - 8:53 am: | |
You spun the wheel but did you also grab it and try to wiggle it? |
Post Number: 500 Registered: 10-2003 Posted From: 66.165.176.62
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 08, 2010 - 9:13 am: | |
Yes. No movement or any drag that I could detect. I have also tried to pay attention when going around right of left hand turns to see if there is any noticable difference when the wheel is loaded or unloaded more than on level ground. I guess I need to finda good source for bearing cap seals for a timken axle so I can R&R it |
ED Hackenbruch (Shadowman)
Post Number: 260 Registered: 11-2003 Posted From: 75.244.42.16
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 08, 2010 - 10:16 am: | |
Make sure that all your lug nuts are to torque too. |
Patrick levenson (Zubzub)
Post Number: 179 Registered: 5-2007 Posted From: 70.52.29.59
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 08, 2010 - 12:00 pm: | |
good point about the lug nuts..BTDT.....also what condition is the tire in? |
Post Number: 501 Registered: 10-2003 Posted From: 66.165.176.62
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 08, 2010 - 12:01 pm: | |
Brand new tires. I bought six new firestones last year |
Post Number: 1241 Registered: 12-2000 Posted From: 70.0.247.184
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 08, 2010 - 1:07 pm: | |
worn shocks or suspension componets?? Jack |
Post Number: 502 Registered: 10-2003 Posted From: 66.165.176.62
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 08, 2010 - 2:17 pm: | |
Suspension looks good and all zirk fittings have been recently serviced. Shocks may be a possibilit though I hadn't thought of |
Registered Member Username: Cowlitzcoach
Post Number: 204 Registered: 4-2001 Posted From: 173.152.197.236
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 08, 2010 - 6:58 pm: | |
Doesn't your Flx have torsalastic suspension? If so you may be hearing your torsion bars flexing. |
Post Number: 1158 Registered: 7-2006 Posted From: 75.245.5.185
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 08, 2010 - 8:45 pm: | |
Hey, Mark...good to hear from you....where ya" been? RCB |
Post Number: 503 Registered: 10-2003 Posted From: 74.244.14.221
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 08, 2010 - 10:18 pm: | |
Mark, Yes it does have torsalastic suspension but the rythm seems to change with speed which is why I am suspecting something to do with bearings or shoes. I was really surprised to not hear some telltale sound when I jacked it up. Oh well I guess I need to pick up one of those torque converts we were talking about in another thread so I can remove that wheel without shop air. |
J.C.B. (Eagle)
Registered Member Username: Eagle
Post Number: 158 Registered: 12-2000 Posted From: 166.204.97.170
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 09, 2010 - 8:03 am: | |
Check the rim for cracks. |
Post Number: 454 Registered: 2-2001 Posted From: 184.0.5.73
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 09, 2010 - 11:01 am: | |
Don't assume that anything new is perfect. Lots of defective new stuff in the world. Try moving the tire to another position. That will tell you whether it's the tire and rime or something else. |
Grant Thiessen (Busshawg)
Post Number: 241 Registered: 10-2007 Posted From: 206.45.93.160
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 09, 2010 - 3:48 pm: | |
Your right Jim could very well be the tire itself. |
Post Number: 205 Registered: 4-2001 Posted From: 173.152.197.236
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 09, 2010 - 5:06 pm: | |
Mark hasn't been heard from much because Mark is a stay-at-home dad with a 19-month. Currently, anything bus related tends to not get done unless it is a dire emergency. And then the little one tags along to supervise. |
Post Number: 206 Registered: 4-2001 Posted From: 173.152.197.236
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 09, 2010 - 5:15 pm: | |
I suppose some more troubleshooting is required. When you say a rythmic squeak or rubbing sound, at what road speed does it occur? Does it occur every time that speed is achieved? Does it ever go away? If it does go away, what conditions cause it to go away? Does it get louder or is it always the same sound level? If it does get louder, what conditions cause it to be louder? I am still inclined to think the suspension but a cracked wheel or tire going bad could still be the culprit. Good luck on the troubleshooting. |
Post Number: 261 Registered: 11-2003 Posted From: 75.242.114.194
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 09, 2010 - 5:49 pm: | |
And i am still betting that one or more of the lug nuts is not tight. :>) |
Post Number: 262 Registered: 11-2003 Posted From: 75.242.114.194
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 09, 2010 - 5:50 pm: | |
It is also the quickest thing to check and doesn't cost a thing. |
Post Number: 436 Registered: 10-2004 Posted From: 173.77.219.254
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 09, 2010 - 8:02 pm: | |
Well I hope it is a loose lug nut but several years ago we had that and it was a wheel bearing on the curb side. It started as a steady squeak that got louder after about 200-300 miles. Repair wasent too difficult but i did have to get the bearing ordered at the local bearing place in Ocala Fla. Parts with shipping were around 85.00 in 02. Good luck |
Post Number: 437 Registered: 10-2004 Posted From: 173.77.219.254
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 09, 2010 - 8:05 pm: | |
