Fred Nelken (Faster_freddie)
Registered Member Username: Faster_freddie
Post Number: 45 Registered: 1-2005 Posted From: 75.245.79.44
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 12, 2010 - 12:26 am: | |
I may need a set of re-maned heads for my MCI 8V92TA. Does anybody know where I can get a set at a good price in the western U.S.? |
Post Number: 1690 Registered: 12-2000 Posted From: 67.182.48.162
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 12, 2010 - 1:29 am: | |
Fred - Don Fairchild may have a lead on some. Clifford may jump in, too. Pedco in Santa Fe Springs, CA Delaney & Alf in Bakersfield, CA. Those are a few ideas that come to mind. FWIW & HTH. . .
larry currier (Larryc)
Post Number: 317 Registered: 2-2007 Posted From: 64.40.61.231
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 16, 2010 - 3:41 pm: | |
I always repair my heads, then I know what I've got. Any decent diesel shop can pressure check and repair your heads as needed. If you have cracked a head, I would then consider a recon unit, but many recon heads have had cracks welded and come with a 90 day warrantee... You can buy a new, bare head from DD and reuse most or all of the small parts usually including the valves. At least you know what you have. Can't imagine you ever needing to replace both heads at once, not much difference between a new one and a used one as long as they are not blowing water out the fill hole. |
