Grease Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2010 » April 2010 » Grease « Previous Next »
Username: Timb
Post Number: 510
Posted From: 66.165.176.62
Posted on Friday, March 26, 2010 - 10:11 am:
Hello busnuts,
Is there a particular grease you guys use when hitting the zirc fittings on the suspension and slack adjusters?
Post Number: 850
Posted From: 71.53.153.91
Posted on Friday, March 26, 2010 - 1:37 pm:
Synthetic grease is the best because it doesn't dry out and repells water and lubs better!
gomer
Username: Gusc
Post Number: 1133
Posted From: 173.202.22.55
Posted on Friday, March 26, 2010 - 6:41 pm:
Grease is grease. Today even bearing and chassis grease are often one and the same. Took me a while to accept that one!
The parts you mentioned use plain ole chassis grease as recommended in most bus manuals.
The little bit most of us use our buses probably doesn't call for anything exotic.
David Guglielmetti (Daveg)
Username: Daveg
Post Number: 156
Posted From: 66.122.182.221
Posted on Friday, March 26, 2010 - 7:31 pm:
Any grease is better than no grease. Chassis lube is generally NLGI #2, while I prefer a #1 for auto-slacks...again, we all have our preferences but I would cautiously say that grease is not as critical as oil with regards to old buses and two-stroke engines.
Bill Holstein (Billmoocow)
Username: Billmoocow
Post Number: 60
Posted From: 98.232.207.25
Posted on Saturday, March 27, 2010 - 2:08 am:
I think they would be happy with just about anything if you where to give them attention. Probably something that should be more pampered but is not.
Username: Timb
Post Number: 511
Posted From: 74.244.14.221
Posted on Saturday, March 27, 2010 - 3:08 pm:
Thanks guys. I had a hard time acepting wheel bearing and chasis could be the same thing as well. I remember certain applications in the past needed something with moly in it and didn't know if there were any special requirements for our HD equipment
Patrick levenson (Zubzub)
Username: Zubzub
Post Number: 197
Posted From: 174.91.225.235
Posted on Saturday, March 27, 2010 - 7:02 pm:
I like the red/pink synthetic. It's pretty. Doesn't really cost much more than the regular stuff if you are buying by the tube. And it's Prettier!
Post Number: 851
Posted on Saturday, March 27, 2010 - 10:24 pm:
I tried to post awhile ago and I lost my network so I will say it again. Synthetic is a little more in price than petroleum grease but it is more stickable[LOL]than it is also. It is water resistance and will stay in place long after pet grease has gone. I just use it wherever I need grease and try to wash it off with soap, It ain't gonna happen it will take thinner,gas or somthing like that. I am not selling AmzOil product however I use them exclusive whenever I can,not in the DD engine tho. I use it in my cars and trucks tho. Not Mobile 1 Or anyother synthetic,Just AmzOil Period!! It may cost more but the results are far worth the extra money.
My thought only and I don't want to offend ANYONE with this post!!
Gomer
George Martinez (Foohorse)
Username: Foohorse
Post Number: 58
Posted From: 76.109.100.30
Posted on Saturday, March 27, 2010 - 11:39 pm:
myself I like the pretty red grease as well. but the blue marine stuff is hard to resist, it also is very pretty.
Username: Zubzub
Post Number: 198
Posted on Sunday, March 28, 2010 - 2:39 am:
Oooh Blue!! I hadn't seen the blue. That will go perfectly with my undercarriage.
Post Number: 1836
Posted From: 76.66.17.117
Posted on Sunday, March 28, 2010 - 8:18 am:
I like a grease with some colour in it, so I can tell when it is making it out the other side in applications where that happens, yokes, farm tractor, sleeves, etc. the colour quickly fades once in use, so you can tell when the older lube has been pushed out.
My current choice is a Valvoline product called Cerulean, largely for the convenience; I buy the tubes by the case at the local farm supply.
Besides the suggestion that any grease is better than no grease, I would also recommend a powered grease gun: He who gets tired squeezing, tends to squeeze less...
There's a lot of fittings and a lot of contortions to reach them all. It is far too easy to lose one's zeal for excellence in preventive maintenance once the body is complaining!
Username: Dmd
Post Number: 438
Posted From: 173.77.207.138
Posted on Sunday, March 28, 2010 - 11:16 am:
and a small flex hose with a tight fitting adpt on the end. Sometimes a flex helps sometimes you need the hard push of a solid end to get her to take. I love laying under the bus once in a while and checking everthing out while hitting the grease lever. We lost the great multi port fitting bank to the shift linkage during the repower and now i am not as anxious to crawl under with air bags in the rear. as 4 the colors, we have the marine blue now as opposed to the old black then green. Looking foward to getting some red, is this a red/blue state issue? And whats the deal with the powered unit? Drag a air hose with you or is it like the battery powered caulk guns?
Username: Gusc
Post Number: 1135
Posted From: 173.202.36.75
Posted on Sunday, March 28, 2010 - 11:57 am:
I may never be happy with black or dark green grease again after reading about this pretty grease!
Tom Christman (Tchristman)
Username: Tchristman
Post Number: 200
Posted From: 66.218.33.156
Posted on Sunday, March 28, 2010 - 12:26 pm:
Whatever grease says heavy duty high pressure is what you want. Good Luck, TomC
Post Number: 1837
Posted on Sunday, March 28, 2010 - 12:58 pm:
There are old school airline powered grease guns, and new fangled rechargeable battery powered ones.
for example:
http://www.lincolnindustrial.com/asp/products/powlub.asp
I echo the convenience of a good length of flex hose on your grease gun.
Fittings that resist taking on grease should be investigated closely for possible replacement or for blockage.
Username: Foohorse
Post Number: 59
Posted on Sunday, March 28, 2010 - 1:34 pm:
Patrick! there's GREEN also!! if it's British racing green I may wet myself with excitement
Dallas Farnworth (Dallas)
Username: Dallas
Post Number: 34
Posted From: 72.172.43.196
Posted on Sunday, March 28, 2010 - 4:41 pm:
Are you forgetting about the pretty purple with the awesome gold/silver flecks in it from Mystic?
Post Number: 1188
Posted From: 75.245.156.180
Posted on Sunday, March 28, 2010 - 10:19 pm:
Username: Foohorse
Post Number: 60
Posted From: 76.26.21.45
Posted on Monday, March 29, 2010 - 6:02 pm:
AAARRRHHHGG :-O oh boy. must go change... uh never mind. purple with glitter. this must be recommended to the owners of the motor home that was walled with mirrors and lights only thing missing was the pole. thread.. Some Photos for Ideas and Inspiration. LOL
Justin Burie (Justinb)
Username: Justinb
Post Number: 16
Posted From: 209.254.23.194
Posted on Tuesday, March 30, 2010 - 12:54 pm:
[quote="GeorgeMartinez"]
.....there's GREEN also!! if it's British racing green I may wet myself with excitement
Just stay away from their electronics.
From the vintage road racers:
Lucas Electronics = The Prince of Darkness
Username: Gusc
Post Number: 1140
Posted From: 173.202.9.56
Posted on Tuesday, March 30, 2010 - 9:16 pm:
I'm a Brit fan too but my two are bright red and mulberry!!
Username: Foohorse
Post Number: 62
Posted From: 76.109.96.202
Posted on Tuesday, March 30, 2010 - 10:39 pm:
and the lord of room temperature ale, Lucas for a time made refrigerators as well. yes that's good advice Justin although the resulting electrocution may wake the monster more than the blue pill crap. [quote= Dr Frank N Stein] IT'S ALIVE!! AH HA HA HA HA!......uh sorry Tim this threads gone way way south. It's all Patrick's fault
Username: Timb
Post Number: 514
Posted on Wednesday, March 31, 2010 - 9:44 am:
No worries George. I have some old Brit iron as well. When it comes to Lucas you just need the correct tools. http://members.tccoa.com/timb/LucasTool.jpg
John Lacey (Junkman42)
Username: Junkman42
Post Number: 115
Posted From: 69.19.14.31
Posted on Wednesday, March 31, 2010 - 4:40 pm:
Tim, can I assume that You never rode brit bikes back in the fifty's? The only tools I ever thought about would need fuses and matches to correct Joe Lucas problems. I never trusted anything lucas out of sight of street Lights. YMMV John L
Username: Timb
Post Number: 515
Posted on Wednesday, March 31, 2010 - 5:11 pm:
You would be correct John. I have mostly driven BMW twins. I currently have a 68 Jaguar Etype and you are correct I don't venture out too far after dark :-)
Username: Dallas
Post Number: 37
Posted on Wednesday, March 31, 2010 - 10:35 pm:
What about those wonderful Girlig brakes on the UK cars?
Our method was, if it works, there's something wrong... change it!
Username: Junkman42
Post Number: 116
Posted on Thursday, April 01, 2010 - 8:47 am:
Dallas, I always wondered why cars made in a country where there is hardly ever a dry day manufactured cars that leak when it is not even raining! By the way I must admit My father was born in 1912 in the UK, and a lot of My family lives in Canada. I had also a 2+2 v12 etype and I gave up keeping the alternator and ignition system working and did I mention the $250 dollar head gaskets? But when the beast ran it really ran! I loved all of My Brit cars but I loved some of the women no longer in My life! Makes no sense I know. John L
Username: Timb
Post Number: 516
Posted on Thursday, April 01, 2010 - 9:15 am:
John,
I understand that as well....thus why my 2+2 has a GM 1 wire alternator retrofitted. On the plus side you don't have to worry about corrosion on the undercariage with the oil leaks
Username: Kyle4501
Post Number: 549
Posted From: 65.23.106.193
Posted on Thursday, April 01, 2010 - 11:13 am:
On my XJ12L, the 4 carbs leak enough gas to wash off all that oil . . . . :-(
No, I don't drive it much, at less than 10 mpg & less than 20 gallons in the tanks, it requires so many stops for gas, it is almost faster to walk.
It is a nice ride tho . . .
Username: Timb
Post Number: 517
Posted on Thursday, April 01, 2010 - 11:59 am:
I find it kind of interesting that the busnut sickness that afflicts us all seems to have other common vehicular side effects. As if busses aren't enough of a headache from time to time we need british autos to tinker with
Username: Kyle4501
Post Number: 550
Posted on Thursday, April 01, 2010 - 1:17 pm:
If you own a dog, you may as well own a cat too.
Username: Foohorse
Post Number: 63
Posted From: 174.48.4.129
Posted on Thursday, April 01, 2010 - 6:49 pm:
Tim I believe that the sickness you are referring to is masochism. But in defense of Mother England and the fine craftsman there. My 1961 Rolls Royce Silver Cloud II has been without a doubt the most trouble free car I have ever owned Asian products included. huge appetite for fuel, but a great car nonetheless. I miss her
