doug yes (Dougg)
Post Number: 125 Registered: 1-2007 Posted From: 174.131.66.128
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, April 02, 2010 - 4:43 pm: | |
Has anyone tried these wall mount units that vent outside through 2 hoses? Any opinions? http://kingersons.com/highseer-minipackaged-12k.htm |
Post Number: 534 Registered: 8-2004 Posted From: 149.168.204.4
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, April 02, 2010 - 11:41 pm: | |
First thing that I'd ask is would it stand up to the stresses (vibration, "road shocks", etc) of use in a bus. (I'm not saying that it wouldn't, I would just like some assurance - mfr or private owner's experience - that it would live in a bus). Looks good, though, doesn't it? And at 10 AMPs on 110v. |
Post Number: 1869 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, April 03, 2010 - 10:12 am: | |
those dimensions would eat up valuable wall space. |
George M. Todd (George_todd)
Post Number: 968 Registered: 8-2006 Posted From: 64.55.111.6
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, April 03, 2010 - 10:57 pm: | |
Look closely at their pictures! The reason it runs with "...no copper tubing between units..." is because the outside unit bolts on the outside of the "wall," directly outside of the indoor unit! Then there's the "18 inch drain tube" on the outside? We're going to run it down the side of the bus and into the wheel well? 10 Amps at 120 Volts is 12 EER, which isn't bad, IF that occurs at 95 degrees outdoor. Unfortunately they mention SEER, which is measured at 82 degrees outdoor, which means a lot higher amp draw as the outdoor temp increases. Too wide for everybody with a 102, $1300+ for 12,000 BTU, versus less than a grand for a rooftop with 13,500 or 15,000 BTU? Its maximum outdoor working temperature is 99 degrees, which makes is worthless in the Southwest. G |
Post Number: 1203 Registered: 7-2006 Posted From: 75.243.151.126
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, April 03, 2010 - 11:10 pm: | |
...thanx, G RCB |
