Registered Member Username: Muziklvr
Post Number: 79 Registered: 7-2006 Posted From: 69.171.173.109
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 09, 2010 - 8:56 pm: | |
hey guys. was wondering if anyone could give me any advice on how to get the factoty ac coil out with out damaging the factory road heat(radiator) that is located just behind the entrance steps???? |
Post Number: 901 Registered: 3-2007 Posted From: 71.53.153.91
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 09, 2010 - 10:04 pm: | |
Chris! The ac coil will slid out of a slot after you unhook the lines and hold down bolts. You may have to cut the bolts as they have been in a long time, however they will release the coil and I even had to take the unit with a come a long but it came out. I pulled the heater core out of one and had a fit with it also,but prying and tugging it finally came out too. gomer |
thomas flocks (Taflocks)
Registered Member Username: Taflocks
Post Number: 264 Registered: 9-2009 Posted From: 74.76.246.165
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 10, 2010 - 6:55 am: | |
my pipes seem to be capped off going no where and i have no defroster heat.how can i make mine work? |
Post Number: 902 Registered: 3-2007 Posted From: 71.53.153.91
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 10, 2010 - 8:04 am: | |
Tom On my 04 when I took the heater out from below, the lines to the heater were plugged and that allowed the main lines to supply the defroster heater core. There is valves in the rear and I turned them on and checked everything and all was well there. You also have a control in the dash for the core and it may be off or stuck in the off position check it out too. Let me know what is up. Gomer |
Post Number: 80 Registered: 7-2006 Posted From: 69.171.173.60
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 10, 2010 - 10:51 am: | |
marvin,is there any special hold down bolts?does it bolt to the heater core which sits directly behind it?how hard of a job is it?the old compressor is long,long,gone.i guess what i want to know is can it be done in a day ,or does it take 3 ?!?!?! lol.tryin to see what im in for? |
Post Number: 81 Registered: 7-2006 Posted From: 69.171.173.60
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 10, 2010 - 10:54 am: | |
marvin,what yr is your 4104? does it have both the front and rear caps? i can see the rear cap in your pic ,but was wondering if you had one on the front as well? |
Post Number: 903 Registered: 3-2007 Posted From: 71.53.153.91
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 10, 2010 - 1:55 pm: | |
Chris It won't take but a little while to take the thing out. the hardest part maybe finding the clamps/bolts if they are still there. The 04 is a 1957 and I hope these will come thru. Yes it has front and rear RM caps,and tailgate. The front lights was a special order at the time and looks great. I think LOL Gomer |
Post Number: 82 Registered: 7-2006 Posted From: 69.171.173.249
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 10, 2010 - 5:23 pm: | |
gomer , mine is a 1954(#1214),but somehow was titled as a 57 when it was taken out of service many many moons ago. i,too have front and reaar r&m caps. the tailgate is my next purchase. i have been toungelashed by some for "ruining" the look of the classic line by adding the front and rear caps.....beauty is in the eye of the beholder i suppose,kinda like women.....some like em big at the bottom,big at the top,or both! lol |
Post Number: 904 Registered: 3-2007 Posted From: 71.53.153.91
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 10, 2010 - 10:02 pm: | |
George Martinez (Foohorse)
Post Number: 129 Registered: 1-2010 Posted From: 174.48.6.180
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 11, 2010 - 9:38 pm: | |
Marvin you are beginning to repeat yourself, did you forget your meds? |
Post Number: 908 Registered: 3-2007 Posted From: 71.53.153.91
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 11, 2010 - 10:00 pm: | |
TOOOO much vit-E LOL Gomer |
Post Number: 133 Registered: 1-2010 Posted From: 174.48.6.180
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 11, 2010 - 10:47 pm: | |
Easy with that stuff. I don't want to be liable for your overdosing. |
