Wire nest Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2010 » July 2010 » Wire nest « Previous Next »
Bill Holstein (Billmoocow)
Username: Billmoocow
Post Number: 112
Posted From: 71.59.162.64
Posted on Saturday, June 05, 2010 - 12:20 am:
Found another wire nest on my bus. When i first got the bus, i found the one up front on outside drivers side. Today, i was looking for some @#$%^&* air leaks and discovered another wire nest. I was looking around the engine compartment on drivers side. I had my arm in there and felt a burning sensation on back of my arm. I pulled my arm away and the burn, shock sensation went away. Put my arm back in there again and it did it again. I thought i was loosing my mind. It turns out the ground cable to the wire nest was broke off. It was using my arm as the ground path. I hooked the ground back up and wala, no more 24v burning sensation going though my arm. Anyway, i took the cover off to inspect said wiring. I put the cover back and told myself i was in unchartered territory for right now. It looked kinda gross in there. Is there any kind of spray i can put on those wires to give them rejuvination and keep them from corroding?
Post Number: 1193
Posted From: 99.12.241.82
Posted on Saturday, June 05, 2010 - 6:43 am:
That is the designed purpose of WD 40.
FF
Post Number: 113
Posted From: 67.160.147.64
Posted on Saturday, June 05, 2010 - 1:18 pm:
Thanks Fred. Should i disconect the batteries first before i spray? Or does it even matter?
Username: Jackconrad
Post Number: 1301
Posted From: 71.71.3.170
Posted on Saturday, June 05, 2010 - 6:19 pm:
I don't think it matters, as WD-40 is non conductive and we are talking low voltage (< 30 volts). Jack
Username: John_mc9
Post Number: 1156
Posted From: 74.162.75.195
Posted on Saturday, June 05, 2010 - 7:08 pm:
WD-40 is also flammable. I think I'd find a more suitable cleaner for wires.... one that doesn't leave an oily residue.
Post Number: 114
Posted on Saturday, June 05, 2010 - 9:55 pm:
Jack, is that what you spray on your wire nests?
Post Number: 1195
Posted on Sunday, June 06, 2010 - 6:05 am:
WD being flammable is why some folks would carry it,
INSTEAD of Ether to attempt a lazy restart after running out of fuel.
Ether will do immense damage to a warm engine , and is only useful below freezing.
A proper fuel system refilling method is still the safest.
FF
Post Number: 1303
Posted on Sunday, June 06, 2010 - 9:50 am:
I eliminated my wire nest by removing all the OEM cloth insulated wiring and replace all wiring with new wire. Jack
Tom Christman (Tchristman)
Username: Tchristman
Post Number: 225
Posted From: 66.218.33.156
Posted on Sunday, June 06, 2010 - 12:01 pm:
Jack-I think you have it backwards-WD-40 is conductive. I use it on my trailer plug to both clean it and to have a good electrical contact right before hooking up my car. Good Luck, TomC
Username: Jack_fids
Post Number: 91
Posted From: 69.171.160.202
Posted on Monday, June 07, 2010 - 1:25 am:
This is needless confusion over something simple
here's the straight story on WD-40
Where it came from what it was for and what it's good for now... sometimes
the one thing no mentioned is how good it works for cutting Aluminum on a Band Saw or a Table Saw.
Jim Wallin (Powderseeker01)
Username: Powderseeker01
Post Number: 76
Posted From: 208.68.48.77
Posted on Monday, June 07, 2010 - 8:30 am:
Actually, the LPS series of contact cleaners may be a better choice for these tasks. WD40, like PB Blaster is a penetrating lubricant with a residue likley to attract dirt and debris over time.
Grant Thiessen (Busshawg)
Username: Busshawg
Post Number: 260
Posted From: 206.45.93.160
Posted on Monday, June 07, 2010 - 11:38 am:
discontect your batteries and use brake cleaner, that stuff works good, I always have a can handy
Username: Jack_fids
Post Number: 92
Posted From: 69.171.160.69
Posted on Monday, June 07, 2010 - 12:34 pm:
OR...
you could just use a can of aerosol CONTACT and wire cleaner like a lot of Electricians use for cleaning oxidation from the problem areas.....
Post Number: 115
Posted on Monday, June 07, 2010 - 1:20 pm:
Thanks for the ideas.
Justin Burie (Justinb)
Username: Justinb
Post Number: 25
Posted From: 209.254.23.194
Posted on Tuesday, July 06, 2010 - 2:01 pm:
Use a contact cleaner & then follow up by replacing any corded wire &/or terminals. Re-assemble with a coating of dielectric grease.
DRI by State Chemical will take the green right off of the contact.
