steve wardwell (Steve_wardwell)
Registered Member Username: Steve_wardwell
Post Number: 13 Registered: 2-2010 Posted From: 75.203.20.77
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 14, 2010 - 9:23 am: | |
seem to have a little dribble of gear oil on my drive axle rim. Is this going to be a big hassle?Am I going to need to buy a seal or can I use some goop? |
larry currier (Larryc)
Post Number: 328 Registered: 2-2007 Posted From: 207.200.116.13
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 14, 2010 - 1:10 pm: | |
Find out where it's comming from first. Some hubs have a drain plug that can leak. Is there oil on the brake shoes? If they are wet, you will need to change the seal for sure. If it is just the outer axle seal, you can remove the axle and use silacone. |
Ralph Peters (Ralph7)
Post Number: 119 Registered: 3-2004 Posted From: 75.224.0.37
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 14, 2010 - 6:41 pm: | |
First if the shield(slinger) is doing its job there will NOT be oil on the shoes. When the wheel seal leaks the shield funnels it to holes in the drum/hub area and out the wheel, over flow will go down inside of drum, then get on shoes. My drive axle seal did just that, but my tag axle seal did not so shoes got wet. Will just clean shoes on tag and reuse. So pull the wheels and drum and check. The seal installer plate was $45.00 last Nov. at NAPA in N.M. Yes I installed new front and drive axle seals last year and the right drive seal acctually cracked and leaked after only 3200miles. |
Post Number: 1894 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 14, 2010 - 7:04 pm: | |
good time to change over or back to synthetic grease packed bearings with appropriate sealing components. Also you can use a propane torch to help sweat the grease out of the pores of the shoes. Get them hot, but not hot enough to damage lining. You'll see the grease/oil sweat out of the shoe. Do it a couple of times with cleaning with a good solvent or brake clean in between heatings.Do this thoughtfully and with care so we don't need to call the fire department. Make sure you get the rivet or bolt holes clean. Do the same for the drum; especially at any cracks. |
Post Number: 1862 Registered: 12-2000 Posted From: 174.91.146.207
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 14, 2010 - 9:21 pm: | |
Do as you feel led, but for the decision making of the busnut novice: you will find no manufacturer or brake engineering person recommend anything but lining replacement, if the shoe is contaminated with axle lube. It cannot be determined to what extent the lube has been absorbed, or to what extent the cleaning techniques employed have worked, or to what extent the cleaning techniques have damaged the linings. What testing has shown is that a contaminated lining cannot grip the inside of the drum as well, and lengthened stopping distances are the result. tough decisions when on a budget. happy coaching! buswarrior |
Registered Member Username: Muziklvr
Post Number: 86 Registered: 7-2006 Posted From: 69.171.173.55
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 16, 2010 - 9:59 pm: | |
how would you check the fluid in a 4104 rearend? |
Post Number: 87 Registered: 7-2006 Posted From: 69.171.173.55
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 16, 2010 - 10:05 pm: | |
the reason i ask is that the right rear outer rim had just a little bit of greese colected in it last spring. i cleaned it off and haven't noticed any other kind of leaks since, but am planning on a 2k mile trip back to the carolinas for the summer.would feel better knowing that the fluid level was correct! |
Post Number: 1181 Registered: 10-2006 Posted From: 76.248.150.30
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 17, 2010 - 6:47 am: | |
"planning on a 2k mile trip back to the carolinas for the summer." That's just a warm up! FF |
Post Number: 16 Registered: 2-2010 Posted From: 75.250.82.39
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 17, 2010 - 9:16 pm: | |
thanks for the advice. If the shoes are wet, babys gunna get a new pair of shoes...(been wantin to say that for a while now lol) thanx much........s....... |
Post Number: 1175 Registered: 11-2005 Posted From: 24.251.120.104
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 17, 2010 - 11:59 pm: | |
Chris, The 4104 uses grease in the hub, not oil from the rear end. If you have oil in the hub your seal/s are leaking. It may be leaking thinned grease onto the wheel because the hub was overfilled with grease. This happened to my front wheels. The hubs are supposed to only be coated with grease, not filled. You check the rear end oil via the plug at the front of the differential housing. My '54 s/n is 1274. (Message edited by gusc on May 18, 2010) (Message edited by gusc on May 18, 2010) |
Post Number: 89 Registered: 7-2006 Posted From: 69.171.173.98
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, May 19, 2010 - 10:41 am: | |
gus,thanks for the info.mine is a 54 as well.#1214,but somehow was titled as a 57.do you tow anything behind yours? if so does it affect your braking?can you feel it back there in the performance? does it affect the fuel milage? im asking b/c i plan on towing a 5200lb minivan on a dolly(that has elec brakes). |
Post Number: 1178 Registered: 11-2005 Posted From: 71.112.182.39
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 31, 2010 - 7:07 pm: | |
Chris, Sorry I missed your post because it was a day after we left for our 3000mi trip and I didn't get back to this board for awhile. The only tow I ever made was 800mi with a Chevy Cavalier with the front wheels on a dolly. It probably weighed 2800 lb or less. I didn't know it was there either under power or braking. A dolly puts very little weight on the hitch and makes towing easy except you can't back up. |
