WTB: Turbo for 8v92 Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2010 » May 2010 » WTB: Turbo for 8v92 « Previous Next »
Jim Huskins (Lostranger)
Username: Lostranger
Post Number: 11
Posted From: 68.238.120.80
Posted on Monday, May 17, 2010 - 9:26 am:
Anyone have a working turbo you'd like to sell? Will any other turbo fit this engine? I'm considering buying a bus that's several hundred miles from home, and it has a hole in the puffer. I have one on a 6v92 (left hand rotation), but I guess that won't work, huh?
Ralph Peters (Ralph7)
Username: Ralph7
Post Number: 121
Posted From: 75.224.122.200
Posted on Monday, May 17, 2010 - 10:17 am:
Jim I tryed your Phone## but it did not work. So call 717-776-7725 Lied Diesel they will know and should some in stock, may have used also. They are in Pa. and ship, daily.
Patrick levenson (Zubzub)
Username: Zubzub
Post Number: 215
Posted From: 174.91.217.34
Posted on Monday, May 17, 2010 - 10:26 am:
Pretty sure the turbo doesn't care which way the engine turns. It's more the size, about it fitting on the exhaust properly, having an output where it's supposed to be and other appropriate fittings....
Post Number: 12
Posted on Monday, May 17, 2010 - 11:51 am:
Thanks Ralph7 for the contact. I'll try to get my number updated soon.
Timothy at Lied Diesel was most helpful. Says the 6v92 turbo will bolt up and work if both engines are same vintage (early or late). I'm checking that further today.
Username: Luvrbus
Post Number: 888
Posted From: 74.32.87.183
Posted on Monday, May 17, 2010 - 12:55 pm:
Get the model number for me I have 3 or 4 here in AZ there are 12 or more for a 8v92 if a high horse hp engine the TV 8511 is a good turbo for torque at the high end but smokes a little on take off.
My advice is check the A/R on both sides the hot side A/R is located inside the hot housing housing, the turbo is matched to the injector,cams and liners so be careful installing any other turbo on the engine.
The model and serial number is located between the 2 housings on the center piece
Post Number: 13
Posted on Monday, May 17, 2010 - 1:02 pm:
I should have been more clear that I'm only interested in getting this bus home. It's about 600 miles from here. As part of the conversion, I'm going to repower with a 50 series coupled to a 13 speed Road Ranger. The 8v92 runs but has a hole in the turbo, and I can't imagine trying to limp it home in that condition.
Thanks for all the response.
Jim
clint hunter (Truthhunter)
Username: Truthhunter
Post Number: 622
Posted From: 24.129.238.13
Posted on Monday, May 17, 2010 - 10:21 pm:
...but did any other engine damage occurs when the hole appeared in the turbo that will make itself apparent a few miles down the road ? might be the same price to have it towed or low bedded home as a haul back, if time isn't short. Phone around for a quote, the local bus shops will know who is equipped.
Post Number: 14
Posted on Tuesday, May 18, 2010 - 3:54 am:
I've learned that my 6v92 turbo is the older style and will not bolt to this 8v92. Does anyone have contact info for a truck wrecking yard near Fancy Gap, VA? I hear they may have the turbo I need, but I don't even know the name of the place.
I've already investigated all the transport options, and none are cost effective. I'm confident I can driver 'er home if I can get the turbo swapped.
Username: Zubzub
Post Number: 217
Posted From: 70.52.29.11
Posted on Tuesday, May 18, 2010 - 8:34 am:
Matlock's Auto Recycling
3132 Fancy Gap Hwy
Hillsville, VA 24343
866-895-1246
Try them...if it's not them they should be able to tell you who is.
Post Number: 1184
Posted From: 76.248.150.30
Posted on Tuesday, May 18, 2010 - 1:31 pm:
"50 series coupled to a 13 speed Road Ranger"
Most coaches do not weigh enough , even with a heavy trailer to need to row thru 13 speeds.
5 or 6 will do as well.
The goal if light is 1350-1400rpm at 60 -65
Or if really heavy 1500rpm or so at 60-65
This is supposed to give the fuel mileage you would expect from a more modern 4 stroke.
The latest thinking in 80,000lb trucks is a 2.64 rear so no power loosing OD is needed.
Top gear is straight thru , most efficient.
FF
Dale Waller (Happycampersrus)
Username: Happycampersrus
Post Number: 381
Posted From: 166.231.114.97
Posted on Tuesday, May 18, 2010 - 4:07 pm:
I live here and it's not Matlocks. LOL
Strickland's Auto & Truck
(276) 755-4429
1564 Old Pipers Gap Rd
Cana, VA 24317
http://www.merchantcircle.com/blogs/Stricklands.Auto.And.Truck.Service.276-755-4429/2009/8 /Stricklands-Truck-and-Auto-Repairs-Salvage-/366667
HTH,
Dale
