Registered Member Username: Muziklvr
Post Number: 95 Registered: 7-2006 Posted From: 69.171.173.220
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 31, 2010 - 10:28 am: | |
this may sound crazy,but exactly where is the tstat housing on a 671,in a 4104? is it centerway of the engine,up on the top,just behind the head?{if you are looking at the engine from behind the bus}and what should the norm op temp be? and how long should it take to reach norm op temp? |
Patrick levenson (Zubzub)
Post Number: 230 Registered: 5-2007 Posted From: 174.91.225.176
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 31, 2010 - 12:41 pm: | |
Do you have the Owners Manual? No real point in caring for an"04 without one. If you need one there are a few here who could send you a PDF of it. And yes it sounds like what you are describing is the tstat housing. It takes awhile to reach op temp, and it won't do it idling, you need to drive it. Can't remember off hand what op temp is....but it's in the book. |
Post Number: 1911 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 31, 2010 - 9:44 pm: | |
Factory was 170 degrees. In horizontal pipe shaped thing at top front of coach side of engine. Thermostat to the left end. Will run on the cool side if not working hard. Shutters will help to keep temp up. |
Austin Scott Davis (Zimtok)
Post Number: 418 Registered: 9-2006 Posted From: 209.156.24.114
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 01, 2010 - 9:46 am: | |
It looks like this (sort of) . |
Post Number: 419 Registered: 9-2006 Posted From: 209.156.24.114
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 01, 2010 - 9:48 am: | |
E-mail me at sdavis@orionpackaging.com and I'll send you a link to download the 4104 manuals. . |
