Sideways Hot Water Tank Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2003 » April 2003 » Sideways Hot Water Tank « Previous Next »
Christopher Auito (Neogeo) (157.130.118.2)
Posted on Monday, April 07, 2003 - 10:58 am:
Does anyone know if there is a hot water tank available anywhere (electric) that I could mount on it's side. Standard residential size would be perfect. (I plan on mounting it in the center aisle and leveling the floor)
Alan Heaberlin (66.159.206.16)
Posted on Tuesday, April 08, 2003 - 12:49 am:
Electric hot water heaters usually have 2 elements and use 1 leg of 240 for each side. The problem is that the hot water stratifies and in the vertical position is designed with a dip tube on the cold water inlet to put the cold water at the bottom. It is a simple matter to remove the dip tube and disconnect one element. Mount the heater so the element is accessible in case you run it dry and have to replace it. =o)
I've thought about doing this with a small electric under the floor of my Flx New Look as an add-on to the puny 11 gal. propane job I'm installing now.
William R. Graf (Billfrombrazil) (198.36.182.66)
Posted on Wednesday, April 09, 2003 - 2:24 pm:
Before you try mounting a tank on its side that was designed to be upright check around. I know that there were horizontal mount water heaters in Brazil and I assume that there is such a thing available here in the U.S.A. I would suggest that you check with a plumber or a plumbing supply to find out who manufactures such a thing.
