Bill Holstein (Billmoocow)
Registered Member Username: Billmoocow
Post Number: 112 Registered: 5-2009 Posted From: 71.59.162.64
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 05, 2010 - 12:20 am: | |
Found another wire nest on my bus. When i first got the bus, i found the one up front on outside drivers side. Today, i was looking for some @#$%^&* air leaks and discovered another wire nest. I was looking around the engine compartment on drivers side. I had my arm in there and felt a burning sensation on back of my arm. I pulled my arm away and the burn, shock sensation went away. Put my arm back in there again and it did it again. I thought i was loosing my mind. It turns out the ground cable to the wire nest was broke off. It was using my arm as the ground path. I hooked the ground back up and wala, no more 24v burning sensation going though my arm. Anyway, i took the cover off to inspect said wiring. I put the cover back and told myself i was in unchartered territory for right now. It looked kinda gross in there. Is there any kind of spray i can put on those wires to give them rejuvination and keep them from corroding? |
Post Number: 1193 Registered: 10-2006 Posted From: 99.12.241.82
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 05, 2010 - 6:43 am: | |
That is the designed purpose of WD 40. FF |
Post Number: 113 Registered: 5-2009 Posted From: 67.160.147.64
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 05, 2010 - 1:18 pm: | |
Thanks Fred. Should i disconect the batteries first before i spray? Or does it even matter? |
Post Number: 1301 Registered: 12-2000 Posted From: 71.71.3.170
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 05, 2010 - 6:19 pm: | |
I don't think it matters, as WD-40 is non conductive and we are talking low voltage (< 30 volts). Jack |
Post Number: 1156 Registered: 7-2006 Posted From: 74.162.75.195
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 05, 2010 - 7:08 pm: | |
WD-40 is also flammable. I think I'd find a more suitable cleaner for wires.... one that doesn't leave an oily residue. |
Post Number: 114 Registered: 5-2009 Posted From: 71.59.162.64
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 05, 2010 - 9:55 pm: | |
Jack, is that what you spray on your wire nests? |
Post Number: 1195 Registered: 10-2006 Posted From: 99.12.241.82
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 06, 2010 - 6:05 am: | |
WD being flammable is why some folks would carry it, INSTEAD of Ether to attempt a lazy restart after running out of fuel. Ether will do immense damage to a warm engine , and is only useful below freezing. A proper fuel system refilling method is still the safest. FF |
Post Number: 1303 Registered: 12-2000 Posted From: 71.71.3.170
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 06, 2010 - 9:50 am: | |
I eliminated my wire nest by removing all the OEM cloth insulated wiring and replace all wiring with new wire. Jack |
Tom Christman (Tchristman)
Post Number: 225 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 06, 2010 - 12:01 pm: | |
Jack-I think you have it backwards-WD-40 is conductive. I use it on my trailer plug to both clean it and to have a good electrical contact right before hooking up my car. Good Luck, TomC |
Post Number: 91 Registered: 1-2009 Posted From: 69.171.160.202
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 07, 2010 - 1:25 am: | |
This is needless confusion over something simple here's the straight story on WD-40 Where it came from what it was for and what it's good for now... sometimes the one thing no mentioned is how good it works for cutting Aluminum on a Band Saw or a Table Saw. |
Jim Wallin (Powderseeker01)
Registered Member Username: Powderseeker01
Post Number: 76 Registered: 10-2008 Posted From: 208.68.48.77
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 07, 2010 - 8:30 am: | |
Actually, the LPS series of contact cleaners may be a better choice for these tasks. WD40, like PB Blaster is a penetrating lubricant with a residue likley to attract dirt and debris over time. |
Grant Thiessen (Busshawg)
Post Number: 260 Registered: 10-2007 Posted From: 206.45.93.160
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 07, 2010 - 11:38 am: | |
discontect your batteries and use brake cleaner, that stuff works good, I always have a can handy |
Post Number: 92 Registered: 1-2009 Posted From: 69.171.160.69
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 07, 2010 - 12:34 pm: | |
OR... you could just use a can of aerosol CONTACT and wire cleaner like a lot of Electricians use for cleaning oxidation from the problem areas..... |
Post Number: 115 Registered: 5-2009 Posted From: 67.160.147.64
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 07, 2010 - 1:20 pm: | |
Thanks for the ideas. |
Justin Burie (Justinb)
Registered Member Username: Justinb
Post Number: 25 Registered: 1-2010 Posted From: 209.254.23.194
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, July 06, 2010 - 2:01 pm: | |
Use a contact cleaner & then follow up by replacing any corded wire &/or terminals. Re-assemble with a coating of dielectric grease. DRI by State Chemical will take the green right off of the contact. |
