Fuel pump question Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2010 » June 2010 » Fuel pump question « Previous Next »
Joe Franklin (Franklinga)
Username: Franklinga
Post Number: 11
Posted From: 66.188.75.167
Posted on Tuesday, June 22, 2010 - 9:20 pm:
I had the engine replaced in my MC9 (8V71) last year with a very good running engine from an MC7. I had a couple of local diesel mechanics to do the change over. Since the donor engine was originally coupled to a 4 speed transmission, it did require a fair amount of change over to install in my coach which of course has the Allison automatic.
Due to time constraints, I only drove the coach locally a couple of times and then it sat in the driveway for about 8 months and I ran the engine only a couple of times for about 30 minutes.
Got the coach out about a month ago and initially it ran exceptionally well. After about a mile the engine began to loose power as if it were running out of fuel. I pulled into a church parking lot and after a minute or so the engine shut down. I summoned a couple of diesel mechanics and about 5 hours later we finally got it running and I managed to get it home before the engine shut off again. I started the engine a couple days later (with some difficulty) and it didn't want to rev up.
We suspected the fuel pump to be the culprit, so I ordered a new fuel pump from Williams Detroit. I was changing out the pump yesterday and I noticed the pump I took off the engine is a LH (left hand) rotation. The pump I bought is a RH rotation, which I thought should be the correct pump. Both pumps have the same casting number and appear to be identical except for the LH/RH rotation indication on the front of each pump.
So, is the RH rotation the correct pump? If it is, how did the engine run with the LH fuel pump?
Username: Luvrbus
Post Number: 905
Posted From: 74.32.84.228
Posted on Tuesday, June 22, 2010 - 9:46 pm:
Joe, fuel pumps are left hand rotating regardless of the engine rotation they always turn to the left sec 2.2 page 1 of da book just in case you need a reference.RH is a high output fuel pump both will work for you
good luck
(Message edited by luvrbus on June 22, 2010)
Username: Bigrigger
Post Number: 424
Posted From: 96.42.5.35
Posted on Tuesday, June 22, 2010 - 9:54 pm:
I had a similar problem on a semi one time and it turned out the interior of the fuel line had deteriorated and swelled until it cut the fuel supply enough the engine wouldn't run. Just another thing besides filters you could check.
Good luck,
John
Post Number: 941
Posted From: 71.55.3.249
Posted on Tuesday, June 22, 2010 - 10:02 pm:
Have you changed your fuel filters? A lot of times when you don't run them much the tank will accumalate algae and it will clog a filter slowly. When you let one set for a time always put stabilizer in it and that way you can be sure the fuel is ok, Just a thought
Gomer
Post Number: 12
Posted on Tuesday, June 22, 2010 - 10:34 pm:
Yep, we pulled both the primary and secondary fuel filter while we were in the church parking lot and both of them were full. I did add some fuel treatment a couple of times, but the fuel is over a year old.
However, I've never changed the filter on the pressure side of the pump,so I'm going to change it as well. I'm also changing out all the fuel lines because they look to be quite old.
I was going thru the archieves and I saw a couple of post where folks have pulled the pick-up tube from the fuel tank and cleaned the strainer on the end of the tube. I took a quick look at the fuel tank and it doesn't appear that you could easily pull the pick-up tube without grinding the weld to pull both tubes out. Does anyone know if you can pull the pick-up tube easily?
I don't usually take the approach of "part swapping" to fix a problem, but the cost of these parts are not all that bad. I'm pretty sure I have a "fuel supply" problem, so this is a much less expensive approach than a tow or mechanic bill.
Thanks guys for your help.
Username: Luvrbus
Post Number: 906
Posted on Tuesday, June 22, 2010 - 10:59 pm:
Joe, those pumps are bad about rounding the fork on the inside check and be sure the fork still has a square in it.
good luck
Post Number: 1214
Posted From: 99.156.66.88
Posted on Wednesday, June 23, 2010 - 6:22 am:
There are 2 types of bug killers .
One drops then to the bottom of the tank, the other keeps them in suspension , for the filters to catch.
Remove a primary and if its covered with small dark particles , that's Ashpalting , old fuel clumping , usually no problem for a bunch of filters.
If it looks like snot on the filter that's the bug bodies .
The bugs ONLY can live in water.
Drain the tank , filter the fuel and stick it back in.
'If you removed all the water and snot , you have the problem solved.
FF
Username: Lsilva
Post Number: 375
Posted From: 72.187.35.208
Posted on Wednesday, June 23, 2010 - 8:51 am:
Add a fuel pressure gauge to the input of the secondary filter, it will tell you all you need to know to trouble shoot fuel problems.
les marston (Les_marston)
Username: Les_marston
Post Number: 85
Posted From: 68.151.225.213
Posted on Wednesday, June 23, 2010 - 11:33 am:
Fred
ON the topic of fuel treatments.
What would you suggest for fuel that could likely stay in a tank for up to 5 years?
Les
Tim (Timkar)
Username: Timkar
Post Number: 141
Posted From: 64.141.73.7
Posted on Wednesday, June 23, 2010 - 10:25 pm:
Used Biobor JF at work (stby gen diesel tanks)and have used it on my own equip as well
http://www.conntect.com/fueladditives/biobor/
HTH....Tim
Post Number: 1216
Posted From: 99.168.83.142
Posted on Thursday, June 24, 2010 - 5:57 am:
For 5 years only getting all the water out first will work.
Sure a heavy dose of 2 kinds of bug killer will help , but if there is water , the tank is vented to air , the bugs will come.
Why not simply drain the tank, and leave it EMPTY?
Seal it best you can and it should be OK.
I find the armored refrigeration glass better as you can see the fuel stream , and any bubbles in it.
FF
Jim Wallin (Powderseeker01)
Username: Powderseeker01
Post Number: 80
Posted From: 208.68.48.77
Posted on Thursday, June 24, 2010 - 9:10 am:
The water source is generally condensation unless there is some sort of leak (unlikley?) In yachts and planes it is very useful to keep the tank full to minimize the opportunity for condensation.
Username: Chessie4905
Post Number: 1916
Posted From: 71.58.71.157
Posted on Thursday, June 24, 2010 - 6:45 pm:
If you correctly wire a pressure sending unit with the proper switch point and connect to a light on the dash, you'll know when you have a supply problem. The Flxible I dismantled, had one hooked to it's filter tap. I'm going to install one on my coach. Use a good fuel gauge, preferably oil filled, but only for diagnostic purposes, unless you run a quality braided line and remote mount it. Engine vibration could cause a gauge failure and fuel leakage on a hot running engine going down the road. That's why they remote mount the oil pressure gauge.
