Post Number: 128 Registered: 10-2004 Posted From: 24.62.45.179
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 30, 2010 - 5:11 pm: | |
One of the great things about this board is that there are few things that have to do with our hobby that someone can't set one (Me) on the correct path. Such was the case when I bought the 7.5 Onan gen and one of you saved me a lot off time and money by giving me the paticulars about that gen.---- Well, I got a line on another Onan gen and I hope you guys can once again keep me on the straight and narrow. The #'s are hard to read but I think they are as follows ser 5.0 FGA3CR16004A Model F7833555536 by a line I mean the guy said to take it and if it runs than we will talk money Thaks in advance again |
Post Number: 1305 Registered: 7-2006 Posted From: 75.243.176.92
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 30, 2010 - 8:46 pm: | |
Doug...FWIW, I am happy with Onan...since I changed to 6.5KW....the other one a 4 or 5 KW (can't remember) I was most "happy" to see behind me....as it were RCB |
Post Number: 432 Registered: 6-2004 Posted From: 66.38.159.33
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 30, 2010 - 11:28 pm: | |
Doug I dont have the exact match for your new one, but Onan's model designationis as follows: 5.0 is the kilowatt rating FGA series identification 3CR 3 is voltage code for 120/240 volts single phase C reconnectable 120 volt 2 wire and 120/240 volts 3 wire R is electric starting Hope this helps Joe. |
George M. Todd (George_todd)
Post Number: 1055 Registered: 8-2006 Posted From: 99.184.9.29
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 30, 2010 - 11:36 pm: | |
Doug, Is there any chance that the model and serial number could be reversed? Could you at least try and start it and tell us what does or doesn't happen? Was it on propane or gasoline? G |
Ralph Peters (Ralph7)
Post Number: 128 Registered: 3-2004 Posted From: 75.206.143.160
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 01, 2010 - 2:16 pm: | |
My Onan is a 5.0, BGA 2 cylinder, very similar. Cummmmmmins is the only parts suplyer, points $20.00 plus $10.00 shipping, condensor $10.00, plus shipping $10.00, they came from different places. I still need to redo the carb. It runs very quiet, and I used the big rubber mounts, and, mine does not charge a battery, and uses the house battery. |
Ednj (Ednj)
Post Number: 277 Registered: 3-2003 Posted From: 68.197.93.69
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 02, 2010 - 12:31 am: | |
Ralph, Try these guys for your Onan parts.= http://stores.ebay.com/CURTIS-SERVICE-CORPORATION |
