Darris B , lost the site. Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2010 » August 2010 » Darris B , lost the site. « Previous Next »
Post Number: 1248
Posted From: 99.153.142.249
Posted on Saturday, July 24, 2010 - 6:53 am:
Have no idea how I lost a book mark , but could anyone post a link to the Darris B site with the fantastic RPM vs gear ratio vs tire size computer?
TIA,
FF
Username: Chessie4905
Post Number: 1935
Posted From: 71.58.71.157
Posted on Saturday, July 24, 2010 - 7:36 am:
www.thebouthilliers.com/4106
Tom Christman (Tchristman)
Username: Tchristman
Post Number: 236
Posted From: 66.218.33.156
Posted on Sunday, July 25, 2010 - 11:41 am:
That calculator at thebouthilliers is incorrect. It says to use the actual diameter of the tire for calculations. That's fine, but you'll always be off by 1.6-1.7mph from the rolling radius advertised with a tire company. If that doesn't bother you-then great! My 11/R-24.5 tire is 476rpm, times 4.56 rear end, times .88 final drive (V730) equals 1910rpm at 60mph. Easy to do yourself. Good Luck, TomC
Username: Rjlong
Post Number: 1707
Posted From: 71.195.124.20
Posted on Sunday, July 25, 2010 - 12:13 pm:
Tom -
Even your calc is off a little, 'cause you rounded UP the bevel gear ratio of the V-730. (0.875 actual vs 0.88 used)
" If that doesn't bother you-then great!"
Hehehehehe :-)
Post Number: 1252
Posted on Sunday, July 25, 2010 - 2:57 pm:
"It says to use the actual diameter of the tire for calculations. That's fine, but you'll always be off by 1.6-1.7mph from the rolling radius advertised with a tire company."
To find the actual diameter the drill is a chalk mark, count 10 revolutions and do da math.
OFF by 1 mph is just fine for my mental masturbation.
I also discount the increase in tire diameter from centrifugal force at 75, and the larger diameter when being at Denver , where the gravity is less than Miami!
YRWV
FF
Post Number: 1889
Posted From: 174.91.140.242
Posted on Monday, July 26, 2010 - 10:59 pm:
And here's Mallie's calculator, since we're on the topic:
http://www.cwis.net/~mallie/page12.html
Post Number: 1367
Posted From: 24.239.15.161
Posted on Sunday, August 01, 2010 - 11:34 am:
No, this is not the first time the word "masturbation" has appeared on this web site.
Thought you'd like to know.
Thank you, Fast, for both instances.
Post Number: 1896
Posted From: 174.91.144.79
Posted on Monday, August 02, 2010 - 3:19 am:
EH??
