Yanmar 6 kW Diesel Generator Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2003 » April 2003 » Yanmar 6 kW Diesel Generator « Previous Next »
Jeff (Jeff) (68.10.101.219)
Posted on Sunday, April 27, 2003 - 9:35 pm:
Has anyone had any dealings with the Yanmar Diesel Generators? Below is a hyperlink to a site that sells generators and the generator I really am wondering if I should buy. Anybody???
http://www.generatorquotes.com/order/6MM.asp?page=6MM
Super Quiet Yanmar 6 kW Diesel Generator - This Super Quiet Yanmar 6MM diesel generator is suitable for residential and commercial applications This powerful 10 HP Yanmar L100DE set has plenty of power to run your home, job site or business. This unit includes a 10 HP Yanmar L100DE diesel engine, brushless generator end, super quiet sound attenuated enclosure, muffler, replaceable foam air filter elemant, wheel kit w/ handles, 5 gallon fuel tank, automatic shutdowns and an instrument panel w/ warning lights, breakers, outlets and gauges.
Model Number 6MM
Electrical Specifications -
Power Single-Phase ---
Maximum Output 6,000 watts
Continous Output 5,500 watts
Load Amperage at 120 volts ---
Maximum Load 50 Amps
Continous Load 46 Amps
Load Amperage at 240 volts ---
Maximum Load 25 Amps
Continous Load 23 Amps
Engine -
Type Yanmar L100DE
Power 10 HP
Fuel Diesel
Starting System Electric
Consumption -
Consumption at 1/2 load 0.34 gallons/hour
Fuel tank capacity 5.2 gallons
Running time 1/2 load 15 hours
Control Panel -
Key Start Standard
Water Temperature Gauge Standard
Oil Pressure Gauge Standard
Voltmeter Standard
Hourmeter Standard
Water Temperature Shutdown Standard
Oil Pressure Shutdown Standard
Dimensions -
Length 41 inches
Width 26 inches
Height 31 inches
Dry weight 453 lbs
Manufacturer's suggested retail price... $5575
Central Maine Diesel
1594-D Outer Hammond St.
Bangor, ME 04401
Toll-Free Number: (888) 899-0603
Stephen Fessenden (Sffess) (65.130.8.142)
Posted on Sunday, April 27, 2003 - 11:08 pm:
MSR is higher than some people have posted finding a Kubota or Isuzu for.
Peter E (Sdibaja) (64.165.10.231)
Posted on Sunday, April 27, 2003 - 11:36 pm:
I had a Yanmar in my last boat, loved it... very high quality.
this unit is kind of spendy, you are paying a lot for the enclosure... look some more...
6kW Isuzu $4250, in an enclosure (no wheels) $6099
If you are installing in a bus you will probably want to build your own enclosure that fits your rig.
If you are going to be up in high country and high heat: at 6500 feet and 115 degrees
a 10kW will only put out 7.7
a 8kW will only put out 6.1
a 6kW will only put out 4.6
Jeff (Jeff) (163.230.7.4)
Posted on Monday, April 28, 2003 - 4:43 am:
If you went to the hyperlink, you would have seen the price is $3795.00 delivered. The MSRP is $5575.00. I am planning on putting it in my bus. At the size of the box / generator it will fit over the engine compartment in the old air handler of my RTS-06. Being that it is already in it's own box would be one less headache. I know an old friend of mine had a Yanmar 3 cylinder in his sailboat as his iron sail. It worked well for that purpose. I'm just trying to get my 'Ducks' in a row here as I am just finished skinning the windows and will soon be done with the outside work. Ready to frame up the interior and get ready to run wiring and plumming. Thanks for the input.
FAST FRED (65.58.187.84)
Posted on Monday, April 28, 2003 - 5:20 am:
The add doesnt say if its air or water cooled.
The water cooled are inherently quieter and the hot circ water can be used to make almost unlimited domestic hot water , with out loading the electric side.
Yanmar IS a step up from the lawn tractor stuff, with intelligent operation you could expect about 6000+ hours in camper gen set service.
Geoff (Geoff) (66.238.120.216)
Posted on Monday, April 28, 2003 - 7:38 pm:
I went to the web site and they don't say what the engine rpms's are, or if it a two pole or four pole generator end. I suspect it is a belt driven, 3600 rpm (or 3200 rpm with pulleys) unit similar to the Kubota, etc., "Silent Type" enclosed generator sets. Some people have installed these units in their buses, one person has reported a failure, but if you don't plan on putting 20,000 hours on it or overloading it, it may work out well for you. I also considered a "Silent Type" for my RTS at one time-- that enclosure does save a lot of time, although you will have to splice all the wires to move the control panel into the bus. Check this unit out for a similar set-up:
http://www.chinadiesel.com/gen/kubota_silent_type.htm
Dwight (67.213.8.106)
Posted on Tuesday, April 29, 2003 - 12:13 am:
Judgeing from the 10 h.p. I would guess it is a 3600 rpm unit. onan uses a 18 or 20 h.p. engine for a 1800 rpm unit....
willie (64.165.10.231)
Posted on Tuesday, April 29, 2003 - 2:32 pm:
http://www.sunelec.com/Clearance/clearance.html
Posted on Tuesday, April 29, 2003 - 3:41 pm:
http://www.lsbusby.com/diesel.html
