Matthew J Rutkowski (Matt_rutkowski)
Registered Member Username: Matt_rutkowski
Post Number: 18 Registered: 1-2010 Posted From: 166.137.137.6
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, July 20, 2010 - 9:14 pm: | |
Ok so Ralph Peters and I spent about 6 hours last night trying. To figure out how the plumbing used to be connected in my plumbing bay. By the way thanks Ralph ! So we came across what appear to be the pumps they had installed 2 macerator and 1 fresh water are large old but rebuilt galley maid 12 volt pumps. So my question is Ralph thought I should get rid of them for something more modern And efficient . I can see his point however I have found from research today thAt I have $1800.00 worth of pumps does anyone have any experience with these how do they work and are they reliable ? |
steve wardwell (Steve_wardwell)
Registered Member Username: Steve_wardwell
Post Number: 52 Registered: 2-2010 Posted From: 75.200.50.147
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, July 20, 2010 - 9:49 pm: | |
they are from the marine world. was top of the line stuff in its day. they ain't cheap to repair but if their in reasonable shape I would at least look into them. one point I'll make is they use quite a bit of power (lots of amps) as those motors are like starter motors size ( in a 50' Hatteras and up class boat there's usually a lot of charging ability....or replace and sell em on Ebay they will sell easly |
Post Number: 482 Registered: 10-2004 Posted From: 173.77.208.237
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 21, 2010 - 12:17 am: | |
if the belts and pullys are in good shape and dont wobble you could be ok, but i have to agree with the "go modern" sentiment.Lets get a shot of that 6 on your screen name. I had to get someone here to do mine! |
Post Number: 1243 Registered: 10-2006 Posted From: 99.156.68.151
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 21, 2010 - 6:23 am: | |
Most of the Galley Maid waste stuff I have seen is grand . There usually is a macerator end to chop the goodies , and a pump end to add water so the chopped slurry can be moved as desired. IF you have a need to push the stuff a long distance , AND have ample water it woks great as a head pump. Would work fine too as an external tank drain/macerator pump, as the extra water would be easy , and the slurry will go thru a 1 inch hose for a great distance with good rapidity. Boat stuff IS e$pensive , but usually of such quality that its worth a simple rebuild.. IF you can use its features. FF |
