Wheel seal ??? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2010 » August 2010 » Wheel seal ??? « Previous Next »
Grant Thiessen (Busshawg)
Username: Busshawg
Post Number: 267
Posted From: 206.45.93.160
Posted on Tuesday, August 03, 2010 - 11:41 am:
I have replaced wheel bearings and wheel seal, how far should the test drive be before I would feel comforatble that this thing insn't going to leak. I messed up filling oil, I filled through the power divider plug which over filled it. On my first test run it pushed oil out the vent. I went home drained oil to the proper level , then took it on another 40 mile test run and all is dry. Is this far enough to feel comfortable that I didn't blow the seal??
Username: Busshawg
Post Number: 268
Posted on Wednesday, August 04, 2010 - 9:32 am:
well I ended up running about 50 miles through some hills and all is good, whew
Username: Bigrigger
Post Number: 438
Posted From: 96.42.5.35
Posted on Wednesday, August 04, 2010 - 10:41 pm:
Good job Grant. i would have replied to your last post but anything I said would have been a guess. Good luck.
John
