4106 monocoque frame cutting Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2003 » May 2003 » 4106 monocoque frame cutting « Previous Next »
don (Bottomacher) (216.130.152.51)
Posted on Wednesday, May 14, 2003 - 9:03 pm:
I understand that it's a big no-no, but a friend has seen a 4106 with a wheelchair lift installed behind the front wheel well, which necessitated cutting the frame to accomodate the lift. The bus looks like an older conversion, and is not shaped like a banana. Do any of you folks have an idea how this could have been done without damage to the frame? Thanks to all
Don
Doug (68.83.22.146)
Posted on Wednesday, May 14, 2003 - 10:43 pm:
they can be modified....if the modifier has some engineering knowhow.....forces must be dealt with...if not...breaks and sags
