Tom Phillips (Fortyniner)
Registered Member Username: Fortyniner
Post Number: 17 Registered: 2-2010 Posted From: 66.93.216.253
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 22, 2010 - 12:55 pm: | |
Hi folks, as some of you know I just picked up a 4106 last week and am starting to do some fixup. Part of that is undoing a weird suspension mod to raise the bus up. Part of the mod was replacing the steel bumpstop tubes with longer ones! While the manual specifies the rubber pad length, it does not appear to specify the tube length (why would it). Could any 4106 owners provide either the front/rear frame to axle dimensions when down on the stops or bumpstop to frame dimensions so I can restore the suspension to original specs? Tom Phillips. pd4905a pd4106 |
