Rick (12.250.175.227)
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, May 22, 2003 - 11:25 pm: | |
My Brother gave me the old dish from his Prevost but someone cut the wires and removed the controls I can't find a name on the thing anywhere. It has one coax and an 8 pin conector. How many difernt dishes are there? Thanks Rick |
David & Lorna Schinske (Davidschinske) (64.24.236.82)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 23, 2003 - 8:14 am: | |
Many names same dish basically. What you are interested in is the feedhorn. There are dual LNB, single LNB, Low temp LNB. You can even use a small KU-Band dish for Direct & Dish as long as you have the right LNB. Lorna |
Gary Carter (67.0.81.188)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 23, 2003 - 1:11 pm: | |
If you are talking about the mount you probably have a Moto-Sat. |
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 23, 2003 - 7:25 pm: | |
And here I thought you were going to talk about saucers, plates, platters and cups and stuff. He he he |
jmaxwell (66.42.92.17)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 25, 2003 - 11:32 am: | |
As Gary says, in all likelyhood you have a Moto-Sat since until recently they were the most common of the signal seeking systems. Along with the dish itself, you will need a receiver with a low-speed data port, which does not come with all recievers (usually u have to buy a more upgraded receiver to get this port). It is for a feedback between the dish and receiver and that is the purpose of the 8-pin DIN connector. 2nd most likely maker is Datron. Assuming this to be an earlier unit, it will probably not give u optimum service for DISH 500 but should work fine for Direct TV. It will also work for DISH, but will have to move btwn 2 satellites, depending on what u choose to watch. If u get the FMCA magazine, try contacting one of the advertisers in the back that deal in satellite equipment. They should be able to get u going with parts |
