Post Number: 1036 Registered: 10-2004 Posted From: 75.201.160.106
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 26, 2010 - 7:04 pm: | |
desperately looking for a good used radiator for our coach which is a Prevost H3-40 8v92 auto. The radiator is 39 inches between the tanks per Prevost. Anyone know a salvage yard that MIGHT have a good one? Thanks... |
Post Number: 440 Registered: 6-2004 Posted From: 66.38.159.33
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 26, 2010 - 7:57 pm: | |
Ace What is the width,how many inches wide (thick) and how many rows? |
Post Number: 1037 Registered: 10-2004 Posted From: 75.201.160.106
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 26, 2010 - 8:06 pm: | |
Joe all I know at this time is that it's 39 inches wide without the tanks, about 36 inches tall and about 5 inches thick. As for rows, not sure on that. The Prevost part number is 550-609 and they want a whopping $3411.10. Now you see why I am looking for a good used one! Mine is total toast! |
Post Number: 1370 Registered: 7-2006 Posted From: 75.211.62.119
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 26, 2010 - 8:10 pm: | |
Ace....I didn't think (that maybe a problem right there...))desperate was in your vocabulary!!... Best wishes! RCB |
Post Number: 1038 Registered: 10-2004 Posted From: 75.201.160.106
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 26, 2010 - 8:20 pm: | |
Well its considered desperate because 6 or 7 of us are/were going on a mini rally Labor day, and THAT'S next weekend! |
Post Number: 1948 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 26, 2010 - 9:13 pm: | |
you could probably get a replacement core from Detroit Radiator or one of the other major radiator companies for a LOT less, however not on such a short notice. |
Brian Elfert (Belfert)
Registered Member Username: Belfert
Post Number: 88 Registered: 7-2006 Posted From: 75.221.151.55
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 26, 2010 - 11:02 pm: | |
I found a local radiator shop that mostly does heavy duty radiators. They had the right core on the shelf. I would check to see if you have a similiar shop locally. |
Post Number: 441 Registered: 6-2004 Posted From: 66.38.159.33
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 26, 2010 - 11:41 pm: | |
Ace It looks that the radiator for the 6v92 is 3 inches narrower 36 inches wide and might work in a pinch. I have a new one, no it is not for sale!!!! Keep looking in your neck of the woods, there should be something there. Joe. |
Post Number: 606 Registered: 9-2004 Posted From: 65.23.106.193
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 27, 2010 - 8:08 am: | |
Try http://www.generalradiator.com/ I have not bought anything from them, but my friends that have were pleased with the parts & price. |
Post Number: 1951 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 27, 2010 - 5:09 pm: | |
Do not go with less than you have because you are in a hurry. Most of those big radiator manufacturers that sell to the public, will take calls and if you supply them the CORE dimensions, header dimensions and hole size and number of holes and number of tubes and fin density, they can supply you what you need. They can also make cores with more or different tube/fin setup for better cooling in problem situations.These can be direct shipped. |
Post Number: 1039 Registered: 10-2004 Posted From: 75.201.192.117
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 27, 2010 - 5:36 pm: | |
Thanks Guys! I think I have made a deal on one (same oem part number) out a like bus for a whole lot less than Prevost and it ships out Monday! Oh and it's only 6 months old from Prevost! (Message edited by ace on August 27, 2010) |
Registered Member Username: Davidanderson
Post Number: 261 Registered: 2-2004 Posted From: 69.153.67.228
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 27, 2010 - 6:01 pm: | |
Way to go!! It's nice when the "parts stars" align. $3400 is way out there. David |
Post Number: 1374 Registered: 7-2006 Posted From: 75.211.78.225
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, August 27, 2010 - 9:37 pm: | |
Ace....as I said earlier....well, you know! Congrats....(hope it arrives.....on time...) RCB |
