dounan.morton (65.96.85.207)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 25, 2003 - 10:03 am: | |
i'm finally having the rack set, but am i wasting my time doing it with the wrong injector installed . i changed from a 2 to a 4 valve head leaving in the 7A75 injectors and jakes that came installed on the donor head. also i need to put oil in to start this up after a crank change , does it matter if i use a cheap multi just for this startup. i mean to change this before the engine package even goes back in the "04" thanks in advance , dounan |
Joel Lanstra (Joel) (209.204.150.67)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 26, 2003 - 9:41 am: | |
Considering the costs of working on a diesel engine, do you think it is prudent to cut corners on oil? |
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 26, 2003 - 10:24 am: | |
i'm just talking 1/2 - 1 hour adjusting period, then change out and put in proper oil |
FAST FRED (65.59.73.34)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 26, 2003 - 3:16 pm: | |
THE "Adjusting" will probably be done at or near idle. Not enough temp for the flour reaction to thicken the multi weight oil , so you would have rather low oil pressure with DD's notoriously low ideling pressure pushing 10wt oil. This could cost way more than 8 gal of DD 40wt. FAST FRED |
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, May 26, 2003 - 6:45 pm: | |
okay i'll go for the straight 40, anything else i should know? |
FAST FRED (67.75.113.104)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, May 27, 2003 - 5:52 am: | |
Valve adjustment is like any old car , injectir timing is fairly easy. BUT ,,IF your running the rack , take plenty of time & try as hard as you can for "Perfection". This is one place NOT to be in a rush , have an old DD fellow show you the tricks. IT all has to operate TOGETHER! FAST FRED |
