New radiator Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2010 » September 2010 » New radiator « Previous Next »
Username: Ace
Post Number: 1042
Posted From: 75.203.148.213
Posted on Wednesday, September 01, 2010 - 10:04 pm:
I have a new to me (6 months old) radiator on the truck coming south to me and should be here in a couple of days. Mine is not leaking but it's in sad shape visually! Anyway, I took the time today to start the installation of a mister and the trials show that it will work really well. It's all plumbed and only thing left to do is run 12v wires to the drivers area with a toggle switch. The actual mister is an easy on and off application at the radiator so when it comes time to remove the old and install the new, it will be a snap! The mister I found about 4 years ago and never installed it. It cost me 5 bucks at a wal-mart discount isle and was made to go around a patio umbrella. It is plumbed using an isolated shur-flo water pump and glad that it works good! I know it's more or less a band-aid but none the less, down here a band aid is sometimes needed when it's hot out.
Ace
Cable (Fe2_o3)
Username: Fe2_o3
Post Number: 52
Posted From: 108.17.169.121
Posted on Wednesday, September 01, 2010 - 11:24 pm:
I have a mister also and was playing with the idea of using the 190 deg. warning sending unit to turn it on. Any thoughts?...Cable
Bill Gerrie (Bill_gerrie)
Username: Bill_gerrie
Post Number: 377
Posted From: 216.198.139.38
Posted on Wednesday, September 01, 2010 - 11:53 pm:
Cable
It would run constant at 190 degrees when the switch closes. You will only need it once in awhile when you see the temp rising. You would also need too big a water tank. I only need ours for a few seconds when it is needed then the temp drops to an acceptable level.
Bill
steve wardwell (Steve_wardwell)
Username: Steve_wardwell
Post Number: 87
Posted From: 75.200.13.120
Posted on Thursday, September 02, 2010 - 6:02 pm:
and make sure you use distilled or RO water I found that out the hard way...........s........
Post Number: 977
Posted From: 71.55.13.161
Posted on Thursday, September 02, 2010 - 9:45 pm:
why don't someone come up with a cooler thats made like a moonshine still and run the coolant water thru it, cool it down thru the coils and problem would be solved with misters,extra fans and all the acc. We all have generators big enough to handle the load.. Just thinking out loud.
Gomer
Bill 340 (Bill_340)
Username: Bill_340
Post Number: 114
Posted From: 75.197.194.245
Posted on Thursday, September 02, 2010 - 10:56 pm:
You think Ace was kidding, here is a picture of the local ice cream truck in his neighborhood.. NOW thats funny, I dont care who you are, thats funny.....
J.C.B. (Eagle)
Username: Eagle
Post Number: 161
Posted From: 32.179.184.60
Posted on Tuesday, September 07, 2010 - 8:52 am:
Bill that photo is really cool or should I have said really HOT!!!
Username: Ace
Post Number: 1046
Posted From: 75.202.155.35
Posted on Tuesday, September 07, 2010 - 8:57 am:
LOL that IS funny! Thanks Bill!
