What type oil for power steering on ... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2003 » June 2003 » What type oil for power steering on 80 s transit « Previous Next »
bster (198.81.26.108)
Posted on Friday, June 13, 2003 - 8:53 pm:
i put power steering on 04 using newer style vickers pump with remote resivor and box from transit 80s do i use 10- 40 ?
two dogs (66.90.211.74)
Posted on Friday, June 13, 2003 - 9:56 pm:
automatic transmisson fluid
jmaxwell (66.42.92.5)
Posted on Saturday, June 14, 2003 - 12:28 am:
Mine is a '81 Grumman w/same pump, and specifies 30w, in the manual and on the reservoir.
Bill Gerrie (216.185.72.14)
Posted on Monday, June 16, 2003 - 9:10 am:
If you use a motor oil use a 5 wt. Thin as possible so when it is cool out you don't starve the pump. It makes a lot of noise if the oil is to thick till it warms up. A lot of people use transmission fluid but if the seal in the pump goes it dumps it into the crankcase. Not to good for the bearings. My 2 cents worth. Bill
