Post Number: 1308 Registered: 10-2006 Posted From: 99.189.153.223
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 27, 2010 - 6:20 am: | |
Have recently been reading about Nano Tech. One really interesting concept is they have a nano adative to add to water that makes the water cool up to 40% better. Still experimental, but with every car , truck , genset maker in the world chomping at the bit to reduce costly radiator sizes , it wont be long. For older coaches the new coolant MIGHT allow the fan off times to be far longer , saving a bunch of fuel.AS well as end the fear of going over 210F in a DD and blowing the head gasket. FF |
ED Hackenbruch (Shadowman)
Post Number: 321 Registered: 11-2003 Posted From: 69.98.207.45
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 27, 2010 - 9:09 am: | |
Didn't find the article about a water additive in a quick 2 minute search on google, but did find where they were talking about a coating that they can put on metal that transfers heat 4 times faster than the untreated metal. Interesting, thanks for the info Fred. |
steve wardwell (Steve_wardwell)
Registered Member Username: Steve_wardwell
Post Number: 103 Registered: 2-2010 Posted From: 75.202.92.221
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 27, 2010 - 10:50 am: | |
something like this could solve a lot our overheating problems that plagued many of us this last hot summer .....sounds great! |
Post Number: 1309 Registered: 10-2006 Posted From: 99.189.153.223
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 27, 2010 - 3:43 pm: | |
The most interesting part of the article claimed liquid water has a structure like solid water (ICE). The nano stuff is supposed to break up the water for better cooling. Now dimpled radiator tubing is about all we can do to "break up" the liquid water. I read about it in the tech issue of The Economist , but didn't save the issue. FF (Message edited by FAST FRED on September 27, 2010) |
Post Number: 1968 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, September 27, 2010 - 9:23 pm: | |
If it's that great, it'll be too expensive to use; at least for a couple of years. Like led light bulbs for homes |
Tony Gojenola (Akbusnut)
Registered Member Username: Akbusnut
Post Number: 48 Registered: 11-2006 Posted From: 208.98.151.220
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, October 01, 2010 - 2:41 pm: | |
More information here than I could absorb: http://www.transportation.anl.gov/pdfs/MM/401.pdf tg |
Post Number: 1315 Registered: 10-2006 Posted From: 99.137.210.184
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, October 02, 2010 - 7:16 am: | |
What counts is that a 1% solution may have 25% better cooling. With 100 quarts of coolant in the Sportscar that would only be one quart of majic needed. The real question is will that quart cost a NASA $50,000 or a NAPA $4.95? FF |
