Jerry W Campbell (Jerry_campbell)
Registered Member Username: Jerry_campbell
Post Number: 1 Registered: 5-2010 Posted From: 206.125.82.77
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 29, 2010 - 4:39 pm: | |
Hi Friends, I'm going to put a switch on the kick plate under the sink to interrupt the power going to the pump. So I can turn off the water when needed, like washing you hands without touching the faucet. This means the switch would be normally on and when you push on it it would go off. The pump draws 10 amps. Does anyone know of a switch that would do the job? I've got a couple of 5 amp micro switches that I could hook up in parallel but I'd rather not. Thanks Jerry http://crowncoach.clanteam.com |
les marston (Les_marston)
Post Number: 107 Registered: 1-2010 Posted From: 68.151.225.213
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 29, 2010 - 5:46 pm: | |
look at the switches that are used for turning on and off machinery like routers and table saws. They are an air actuated switch that is stepped on to turn off and again to turn on. I have one for my router table. it handles a 3 hp router and has lasted so far about 10 years. good luck Les |
Post Number: 161 Registered: 1-2009 Posted From: 69.171.161.4
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 29, 2010 - 6:12 pm: | |
Graingers has everything you desire....times 3 |
Post Number: 1970 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 29, 2010 - 7:26 pm: | |
foot operated dimmer switch from any auto parts store |
Post Number: 1313 Registered: 10-2006 Posted From: 99.137.210.170
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 30, 2010 - 6:10 am: | |
Hands free is always great , we used a start button switch to operate the garbage disposal at knee control position. FF |
FloridaCliff (Floridacracker)
Registered Member Username: Floridacracker
Post Number: 438 Registered: 7-2004 Posted From: 68.204.16.36
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 30, 2010 - 7:24 am: | |
Just don't lean forward against the cabinet while your cleaning it out.... Then You would be "Hands free" Cliff |
Post Number: 2 Registered: 5-2010 Posted From: 206.125.86.23
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 30, 2010 - 10:15 am: | |
Thanks, I found a flat switch at Graingers that looks like it will do the job. I'm trying to find one that you don't have to push very hard. Thanks Again Jerry |
Post Number: 1181 Registered: 7-2006 Posted From: 74.162.92.20
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, October 01, 2010 - 2:24 am: | |
Put a turn signal relay in line, and just get your timing right.... Cheap n'easy! |
Tom Christman (Tchristman)
Post Number: 257 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 04, 2010 - 12:00 pm: | |
That's a very nifty idea. Just remember not to push the pedal to turn off the water pump when someone is in the shower (which happens more times then you might imagine). I would suggest installing a 12vdc (or 24vdc whichever you use) normally open solenoid valve on both the hot and cold side of the sink. Then all you're turning off is that sink, not the whole system. Good Luck, TomC |
Post Number: 1971 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 04, 2010 - 5:12 pm: | |
how about one of those sensing faucets like at WalMart? |
