MACHINESTS ?????????????? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2003 » June 2003 » MACHINESTS ?????????????? « Previous Next »
two dogs (66.90.210.171)
Posted on Saturday, June 21, 2003 - 9:42 pm:
O.K. anybody out there a machinest...I just had a guy give me a almost new machine that cuts keyways in shafts.he said it cost 4000 new & has only been used twice.it's got all kinds of important looking parts & a booklet & case,I saw in the book somebody was cutting a 1/2 inch keyway in about a 4" shaft..(serious stuff)
do any of you know more than I do about it& what would it sell for..it's kinda non bus related,but I don't know who to ask
Rich (24.62.243.137)
Posted on Saturday, June 21, 2003 - 10:33 pm:
Sounds like a milling machine. It could be either a vertical or horizontal miller, but more information would be needed. Would need to know what brand it is and exactly how old in order to give a fair value to it. HP of the motor, single phase or three phase. The size of the working table. Also all the stuff that goes with it would be nice to know more about what it is in order to access a value to it. The best thing to do would be to have pictures you could email.
FWIW,
Rich
two dogs (66.90.217.233)
Posted on Saturday, June 21, 2003 - 11:38 pm:
the whole thing attaches to the shaft, will give more info tom. when I can see...it's just for cutting keyways
Posted on Saturday, June 21, 2003 - 11:43 pm:
It also might be a broaching machine, if it's set up to specifcally cut keyways and not much else. But if it can't cut a key in the inside of a pulley bore, it's probably a vertical mill as Rich says.
Send us a photo and it'll be an instant call....
Posted on Saturday, June 21, 2003 - 11:56 pm:
no digital camera...but will have specks in the morning...it's just for keyways, not a milling machine,,you can tell it's almost new,the case everything comes in is about 18"cube
two dogs (66.90.217.171)
Posted on Sunday, June 22, 2003 - 9:33 am:
it's a key mill...model 65, from climax manufacturing co. newberg,oregon
even does tapered shafts shows cutting up to 1 3/8 deep & 1 1/4 wide it looks like an expencive piece of equipment..
Posted on Sunday, June 22, 2003 - 11:29 am:
Interesting... protable keyway cutting mill!!
Here's their website
http://www.cpmt.com/key_mills/index.htm
but this model is probably an old one.
Matt (209.173.120.13)
Posted on Sunday, June 22, 2003 - 11:58 am:
Ha Two Dog are you looking to sell it or what?
two dogs (66.90.217.34)
Posted on Sunday, June 22, 2003 - 12:33 pm:
It's the one on the left,you guys are great..yep,for sale or trade,need 36,000 a/c (OR) whatever..could use some new 24.5 goodyears,or michelan...what ya' got,.....would rather "trade", it's a nice piece of equipment,not junk
Posted on Sunday, June 22, 2003 - 9:08 pm:
for sale but how much? and where are you located.
two dogs (66.90.222.234)
Posted on Sunday, June 22, 2003 - 9:14 pm:
make offer....this unit I was told was 3to4 thousand new..don't want near that,it honestly looks like it's been used an hour...contact:
dosdogs1@juno.com
Phil Dumpster (12.230.214.167)
Posted on Thursday, June 26, 2003 - 1:55 am:
It's a keyway cutter, and yes it probably was several thousand when new. The problem you'll have in trying to sell it is that it is a rather specialized machine, and it's for stuff that is a bit larger than what the home machinist would use. The specs for the one shown on the website is that the minimum shaft diameter it can work with is something like 1.5 inches.
You might try finding a commercial machine shop in your area and see if they might be interested in it. Someone who makes cranes for industry, or other large equipment.
Tom Caffrey (Pvcces) (64.114.233.247)
Posted on Friday, June 27, 2003 - 12:36 am:
Tow Dogs, this sounds like what a boatyard would use to make a new shaft for a boat. Those are usually inch and a half or larger and most are tapered.
Good luck!
Suncatcher
two dogs (67.30.23.8)
Posted on Friday, June 27, 2003 - 1:56 pm:
I might take it with me when I go to the rio grade valley next winter,lots of boats down there,was hopeing to trade it for a couple of steer tires before that..it's a nice looking machine & will cut keyways in a shaft from 7/8" to 10 1/2 in diameter..very little use, although the instruction manual has been handeled with greasy hands..
