Turn signal relays Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2010 » October 2010 » Turn signal relays « Previous Next »
mike leveck (Mikey89032)
Username: Mikey89032
Post Number: 7
Posted From: 63.164.47.2
Posted on Saturday, October 09, 2010 - 10:44 pm:
can anyone tell me where the turn signal light relays are located on a 68-4107? thanks, mike
Post Number: 1012
Posted From: 71.55.1.12
Posted on Sunday, October 10, 2010 - 6:51 am:
Mike I believe yours is in the compartment on your left. Read post above with rogers.
Gomer
Jim Wallin (Powderseeker01)
Username: Powderseeker01
Post Number: 100
Posted From: 70.90.115.49
Posted on Sunday, October 10, 2010 - 7:46 am:
On my 4107 it is in the "glove box" compartment to the right of the entry door, upper left hand corner looking in.
Post Number: 1320
Posted From: 99.168.85.180
Posted on Sunday, October 10, 2010 - 8:15 am:
Turn signal blinker relays come in a variety of AMP sizes.
Be sure NOT to use a car unit if you have many larger lights.
NAPA has HD flashers (truck + Skool bus)in their supply.
FF
Post Number: 8
Posted From: 96.26.148.188
Posted on Sunday, October 10, 2010 - 1:12 pm:
Thanks alot guys, i was thinking it was in the dash somewhere. Mike
Post Number: 1013
Posted on Sunday, October 10, 2010 - 1:28 pm:
Mike I forgot to tell you waht a guy done to me about a flasher the was NOT working. Listen for the clicks and you will find it!!! DUH!! It don't work!!
gomer
Post Number: 9
Posted From: 70.173.26.251
Posted on Sunday, October 10, 2010 - 4:58 pm:
haha, yeah right? i did find them though and found a loose screw on the relay for one of the wires. I tightened it and now they work again. Now i have to figure why my headlights are screwy. one inside and one outside headlamp come on. It should be both insides, correct? Or is it both outsides with low beam?
Username: Rjlong
Post Number: 1724
Posted From: 71.195.124.20
Posted on Sunday, October 10, 2010 - 6:54 pm:
Mike -
Outside lamps are low/hi beam combination.
Inside lamps are hi beam only.
Obviously, then, on low beam both outer lamps should be on.
All four should be on in high beam mode.
Use tell-tale on dash to differentiate which mode you're in.
Break out the volt/ohm meter, it's time to do a little troubleshooting!
FWIW & HTH. . .
