John Zabrocki (John_z)
Registered Member Username: John_z
Post Number: 82 Registered: 9-2006 Posted From: 72.101.245.187
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, October 12, 2010 - 11:00 pm: | |
Anyone have a couple of the fluted panels that go between the windows, or one of the large bay doors? |
L James Jones Jr (Jamo)
Post Number: 157 Registered: 11-2007 Posted From: 74.71.208.254
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 13, 2010 - 6:50 am: | |
I do have the fluted panels, but I really don't want to part with any until I know what I'm doing with my exterior. That won't happen until next summer. Keep my info, and if you have no luck, drop me an email (in the profile). We can keep in touch & I'll know more after we get done with winter. Good luck... |
thomas flocks (Taflocks)
Registered Member Username: Taflocks
Post Number: 372 Registered: 9-2009 Posted From: 74.76.246.165
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 13, 2010 - 8:32 am: | |
check with luke or IBP Industries, Inc. 2055 Sprint Blvd Apopka, FL 32703 (P) 800-468-5287 (F) 407-880-2026 |
Post Number: 83 Registered: 9-2006 Posted From: 72.101.201.59
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 13, 2010 - 10:34 am: | |
Thanks guys, i appreciate the help. Jamo, i have written down your email and will get in touch in the spring. I go to Texas for the winter and will be leaving the bus here in MN this year, so it is not an urgent situation for me. You have one of the first '04s and i have one of the last. Thomas, thanks for the info on IBP, i will be hanging on to that also. |
Post Number: 373 Registered: 9-2009 Posted From: 74.76.246.165
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, October 13, 2010 - 9:54 pm: | |
i just bought 4 bay bottoms 2 smaller ones nos from luke for $291 and 2 large long ones from ibp in the $400 range for both. ibp had to make them to order. |
Post Number: 84 Registered: 9-2006 Posted From: 72.101.201.59
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, October 14, 2010 - 12:01 am: | |
Hi Thomas. Thanks for the info! Have you received the doors from ibp yet? If so, how did they look compared to the oem doors? |
Post Number: 172 Registered: 1-2009 Posted From: 69.171.161.69
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, October 14, 2010 - 1:38 am: | |
I have a large 04 door BUT it is presently working in an 06... I'd love to trade even-up... |
Post Number: 85 Registered: 9-2006 Posted From: 72.101.134.180
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, October 14, 2010 - 10:12 am: | |
Sorry Jack,,, no '06 parts here. Keep me in mind if do find one from an '06 though. |
Post Number: 374 Registered: 9-2009 Posted From: 74.76.246.165
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, October 14, 2010 - 12:44 pm: | |
haven't got them yet, but lukes are fantastic!! i may have to buy more.....keep imn mind i only bought bottoms not the full door |
Post Number: 87 Registered: 9-2006 Posted From: 72.101.134.180
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, October 14, 2010 - 9:26 pm: | |
So did you just get the outer skins for the bottom from Luke? I may have one door that the framework for it may be bent. Not sure at this point if i can just get by with riviting on new skins. |
Post Number: 1324 Registered: 10-2006 Posted From: 99.173.21.139
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, October 15, 2010 - 7:22 am: | |
Not sure at this point if i can just get by with riviting on new skins. REAL rivets , not Smash , not Pop (even aircraft grade) will look the best. FF |
Jim Rink (Fakeguy)
Registered Member Username: Fakeguy
Post Number: 171 Registered: 1-2005 Posted From: 96.11.208.218
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, October 16, 2010 - 7:39 pm: | |
I replaced my fluted panels with some we made from paneling...worked out ok |
Post Number: 1977 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, October 16, 2010 - 8:26 pm: | |
shavehead rivets seem to be real popular nowadays. I think Blyler Rivet sells them and the shaving tool. |
Post Number: 376 Registered: 9-2009 Posted From: 74.76.246.165
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 17, 2010 - 3:12 am: | |
the ones from ipb look great!!! i bought special heads you hammer lightly into the hole in the rivet and you cant tell the difference. if i didn't know better i would say the panel was s/s not aluminum, but they said it was aluminum.Luke didn't have any doors .. |
les marston (Les_marston)
Post Number: 127 Registered: 1-2010 Posted From: 68.151.225.213
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 17, 2010 - 9:44 am: | |
Fred or Thomas Can you tell me where to get these rivets that don't leave the hole in the center like the pop rivets do? I need to replace some in the baggage compartments of our coach and don't want the hole, plus the largest size of rivet that my air riveter will take is still smaller diameter than the original MCI used. Thanks for any info Les |
Post Number: 378 Registered: 9-2009 Posted From: 74.76.246.165
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, October 19, 2010 - 5:19 pm: | |
these are pop rivets with the hole. you hammer the mushroom cap into it and then you have no hole about 10 cents apiece. luke has them in stock. |
Post Number: 1026 Registered: 3-2007 Posted From: 71.55.1.12
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, October 19, 2010 - 5:59 pm: | |
I have used the 3/16 rivet with the mushroom haed that is driven in for years and have never had a problem. I also use seam type sealant with installing the panels/skin and it does not go anywhere. The profile picture of the 04 was done in 1990 and has yet to give any problem. If 3/16's are too small you can get 1/4 in that when they POP the stem is about flush with the top. Can be filled with seam sealer and sanded and it will stay also. I have used this method also. Some 1/4 rivets don't look at all bad left alone and primer/paint does a lot of filling. Gomer |
