Off topic question Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2010 » December 2010 » Off topic question « Previous Next »
les marston (Les_marston)
Username: Les_marston
Post Number: 209
Posted From: 68.151.225.213
Posted on Sunday, December 12, 2010 - 4:42 pm:
A friend and I had a discussion that started out, as most do, over a small item. In this case snowblowers, particularly gas powered with 110 volt AC starters.
The question was this.
My friend insisted that his snowblower starter was polarity sensitive and if plugged in backwards the motor would turn backwards.
This is an AC motor. I know because I had the same unit.
I told him that as far as I know AC motors would still run the same direction if load and neutral got switched.
He claims not....
I looked on the internet but only found that what I believe to be true.
Is there some exceptions to this?
Just one of those niggily things that I have to add to my wealth of useless knowledge
Thanks
Les
thomas flocks (Taflocks)
Username: Taflocks
Post Number: 405
Posted From: 67.253.124.108
Posted on Sunday, December 12, 2010 - 4:45 pm:
it only turns one way if it is ac
macgyver (91flyer)
Username: 91flyer
Post Number: 608
Posted From: 173.217.47.28
Posted on Sunday, December 12, 2010 - 6:11 pm:
The "Polarity Plug" that's used today is there to ensure that ground and hot don't get crossed, since ground and neutral are, in most cases, tied together. Some devices internally ground to neutral, thus avoiding the use of the ground prong altogether...
By plugging it in backwards ("reverse" polarity), you render the internal grounding useless and open the device up for all sorts of fun stuff... including the possiblity of killing you easier (as if electricity needed any help whatsoever in that department!)
Now, I may have my terminology slightly goofed here, and if that's the case, someone correct me... But I believe this to be the reason for the "polarized" plug's introduction...
-Mac
George M. Todd (George_todd)
Username: George_todd
Post Number: 1162
Posted From: 99.56.244.104
Posted on Sunday, December 12, 2010 - 6:19 pm:
Pretty close, but actually the two prong devices are double insulated, instead of having a grounded frame via the third wire.
Older electric dryers and stoves only had a 3 wire plug, with grounding either thru the neutral or a wire from the frame to a water pipe, etc.
A hazard waiting to happen, and a real problem in a bus with completely seperate ground and neutral always.
To answer the question, and please don't hit me.
It is AC right? As in alternating current, as in no polarity? Difference of potential to ground doesn't apply with two wires, so it will always turn the same way, unless the direction of current flow is reversed in the stator with relation to the rotor.
G
(Message edited by George_todd on December 12, 2010)
Post Number: 210
Posted on Sunday, December 12, 2010 - 8:40 pm:
I don't see how it would be possible to change the direction of current flow without rewinding the motor. In that case it would spin the other way however I don't think that some little electrical genie was in the motor magically rewinding it each time the load and neutral got reversed on the two prong plug.
I think that the general consensus is I am right and my friend is mistaken.
Don't get me wrong on this it is not a na na na na na situation
I wasn't out to just prove him wrong. I just was not sure that there was not some way for it to be possible for that little AC starter motor to spin the opposite way
Thanks guys
Les
