Larry (166.133.61.113)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 26, 2001 - 8:29 pm: | |
Got a Prevost with 24 volt system. Wanting to hook up a trailer. Any advise? Wire trailer with 24 volt bulbs or change bus running lights to 12? Any special gizmos to make it easy? anak@francomm.com |
James A Womble (Bubbabusnut) (216.80.157.195)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 27, 2001 - 1:59 am: | |
I just changed bulbs. Best-o-luck bubba |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 27, 2001 - 2:01 am: | |
Bus Jock (64.12.103.176)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 27, 2001 - 1:05 pm: | |
Larry, Easiest and cheapest for a trailer is to change bulbs. But you could buy or make one of the relay boxes. Quite simple, then you would be all setup to tow a car with 12 volt system. Again, if it is always to be a trailer just change bulbs and keep it simple. Jock Fugitt |
Dave-CA (64.111.114.107)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, March 31, 2001 - 2:21 am: | |
TRY A 12 VOLT REGULATOR DRIVING 2N3055 TRANSISTORS FOR A REGULATED OUTPUT THE MORE 2N3055 THE MORE CURRENT 30 TO 50 AMPS POSSIBLE. SINCE TRAILING ANY THING DOESN'T USE HEATERS AIR OR HEADLIGHTS FEW TRANSISTORS ARE NEEDED |
