Powder Coating Question Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » January 2011 » Powder Coating Question « Previous Next »
Username: Dallas
Post Number: 261
Posted From: 72.172.32.121
Posted on Monday, January 03, 2011 - 2:26 pm:
I have a 1952 PD4103 which has the original Trailways anodized aluminum siding. See the picture in my avatar.
It's in pretty rough shape, and needs to have something done to it to make it look better.
I considered paint, but that just doesn't ring my chimes.
I also considered sanding off the anodization and having it redone.... New siding is cheaper, LOL!
Then came Christmas.
Some nice soul bought me a powder coating set up. I won't mention names, but I work for them!
now the question comes:
Can I put a translucent or metallic powder coat over the existing anodizing or does it all still need to be stripped off with a sander and acid, then a chromate bath to assure adhesion?
I am going to build an oven with plywood sides, aluminum lining and an insulation layer. I plan on using 6 - 250 watt infrared bubs and the thermostat out of an electric oven.
I am even open to clear coating the aluminum after the color, using a Diamond or Pearl clear coat.
Pros? Cons? Thoughts? Stupid Idea?
Here are the colors I'd like to use:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=370257184142&ssPageName=STRK:MEWAX:IT
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=320601433255&ssPageName=STRK:MEWAX:IT
Andy Wright (Wrightwy)
Username: Wrightwy
Post Number: 62
Posted From: 75.220.133.8
Posted on Monday, January 03, 2011 - 8:11 pm:
Well I think I would sure give it try. Nothing ventured nothing gained. I like powder coating itclean and tuff Go for it
George Martinez (Foohorse)
Username: Foohorse
Post Number: 295
Posted From: 72.144.168.157
Posted on Monday, January 03, 2011 - 9:21 pm:
letter 41055
Powder coating anodized aluminum parts
I have thousands of small black anodized aluminum parts that I wish to powder coat w/o first stripping. Is there any problem w/ compatibility or significantly diminished adhesion?
Chuck DeWitt
electronics - Hamilton, MT, USA
There is no 100% answer. You can paint over sulfuric anodized parts in most cases. In a few, dye might cause a problem. there are several paints that do not like chromate sealed or chromic acid anodizing. Seal does not make a lot of difference unless the parts are quite old, then sealing helps. Wait a day after anodizing to paint as your powder coat cure temp might cause a lot of water outgassing. I think that unsealed paints better, but I have read several opinions to the contrary. Best is what works for you.
James Watts
- Navarre, Florida
July 31, 2008
Is it possible or is there a specific process to anodize aluminum pre-bend and drilling without molecular failure and eventual flaking off of the finish?
Thomas Babcock
Bozeman, MT, USA
contact button
August 2, 2008
Hi, Thomas. No, I don't think so. Anodizing is a very hard and brittle aluminum oxide ceramic coating. You can't significantly bend it without it badly cracking. If it's going to be bent, chromate conversion coating sounds like a better choice.
Regards,
Username: Dallas
Post Number: 263
Posted on Monday, January 03, 2011 - 9:41 pm:
Thanks George. I read that also. I also read about 10 other pages from my Google search, unfortunately the answers went from "absolutely not" to "Of Course, that's the preferred method!"
Username: Rjlong
Post Number: 1760
Posted From: 71.195.124.20
Posted on Tuesday, January 04, 2011 - 11:04 am:
Dallas -
Perhaps trying it on a small piece first, before attempting the entire coach?
FYI, there were a couple of GM's at Arcadia (an '04 and an '06) that had the anodized aluminum painted. On both coaches, the color match was so good you could not tell that it was paint until you got right up close to it. One of the owners told me all he did was take the fuel filler door into an industrial paint supplier and asked the guy to match the color.
So, even tho paint's not high on your agenda, you might give it another thought.?
FWIW & HTH. . .
Username: Dallas
Post Number: 264
Posted on Tuesday, January 04, 2011 - 11:29 am:
RJ,
I thought long and hard about using paint, but in all actuality, I'm lousy at automotive painting, besides powder coating has a much longer life span and is much more forgiving.
Some of the types I looked at run quite a bit less than $18/lb and cover 70-80 sq. ft. per pound
I plan on getting a bit of experience with the powder coat first. We have a bunch of stuff around here that could stand sprucing up and would benefit from even a bad powder coating job. LOL.
One thing would be my little JD lawn tractor... A girl who worked here a couple of years ago decided that it could go through a pile of trees and brush. It no longer has a hood so I was going to use a piece of ceiling from an MCI 9 and build one for it... Think John Deere Green with FLAMES! hahahahahahaha! (Maybe even a chrome stack and a flapper)!
Username: Ace
Post Number: 1155
Posted From: 173.136.153.85
Posted on Tuesday, January 04, 2011 - 12:14 pm:
Dallas dont think for a moments notice that powder coating is bullet proof. I used to have my race car chassis's done and it WILL chip. You can't just fill it in like you can paint.
Username: Dallas
Post Number: 265
Posted on Tuesday, January 04, 2011 - 12:55 pm:
Yeah, I know, but it's better than the alternative, which is my painting!
Username: Foohorse
Post Number: 296
Posted on Tuesday, January 04, 2011 - 7:03 pm:
You could practice spraying paint as well. I could help when there. heck we could practice on my bus, I was thinking something along the lines of
peter Max's work.
Username: Dallas
Post Number: 268
Posted on Tuesday, January 04, 2011 - 7:12 pm:
I can handle a rattle can with the best of them! I even have one of those fancy handle doo-dads so your finger doesn't get tired pushing the button!
Username: Foohorse
Post Number: 297
Posted on Tuesday, January 04, 2011 - 10:39 pm:
if you can spray paint with a rattle can correctly then you are well advanced enough to take on a real gun even HVLP
Username: Jack_fids
Post Number: 352
Posted From: 69.171.161.62
Posted on Wednesday, January 05, 2011 - 1:36 am:
So as to not lower my reputation...
I'll make no exclamation.
(Message edited by Jack_fids on January 05, 2011)
Post Number: 1160
Posted From: 71.55.1.12
Posted on Wednesday, January 05, 2011 - 9:00 am:
I agree with FOO HORSE.. If you can get that stuff to flow, you can defin-at-ly use a HVLP gun!! The best one I have bought was from of all places Harbor Freight! I have one that was over $200 and the,on sale,2 piece kit for $40 does a better job. Yes I keep them cleaned and ready to use too.
Gomer
les marston (Les_marston)
Username: Les_marston
Post Number: 229
Posted From: 68.151.225.213
Posted on Wednesday, January 05, 2011 - 4:01 pm:
Hey Jack.
I didn't think that the depression of your reputation was ever in question
We know who you are!
Tom Armistead (Oldmansax)
Username: Oldmansax
Post Number: 1
Posted From: 67.142.130.38
Posted on Wednesday, January 05, 2011 - 7:07 pm:
Dallas,
There was a post on the Wanderlodge board I think about removing anodizing. It comes off with Easy Off oven cleaner.
TOM
Username: Dallas
Post Number: 269
Posted on Wednesday, January 05, 2011 - 8:41 pm:
Tom, You have never dealt with the anodizing on the old GM Silversides.
I have used Easy-off, Straight Lye, Muriatic Acid, Pecan Shell blasting, and wet/dry sand paper. This layer is hard and thick!
According to much that I've read, when powder coating, leaving the anodization on is a preferred method.
I have a couple of old pieces of siding I got from another bus that I will try different methods of coating. that is once I get the oven built and the current projects done.
Username: Oldmansax
Post Number: 2
Posted From: 67.142.130.32
Posted on Thursday, January 06, 2011 - 9:30 pm:
Dallas,
At least you are not having to fix a Wanderlodge that was rewired by Doc Brown's (Back to the Future) protegee! I figure we're about even. LOL! You should buy my MCI; then you wouldn't have to deal with the aluminum & I would have enough money the rewire my 'Bird! Give Cat our best belated birthday wishes.
TOM
(Message edited by oldmansax on January 06, 2011)
Username: Dallas
Post Number: 270
Posted on Friday, January 07, 2011 - 7:39 am:
Tom, I like your MCI, it's a nice looking bus.
I have worked on a few Wanderlodges of the 70's vintage and they were pretty well set up. Then I had to do some genset work on an early 90's model and it was a nightmare just trying to follow the poor diagrams and actually trace wiring.
BTW, if I was rich, I'd buy your MCI in a second!
Tom (Oldmansax)
Username: Oldmansax
Post Number: 5
Posted From: 67.142.130.18
Posted on Friday, January 07, 2011 - 7:57 pm:
If I was moderately wealthy, I'd give it to you! LOL!!
