MCI engine swap series 50 Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2003 » September 2003 » MCI engine swap series 50 « Previous Next »
Stephen Fessenden (Sffess) (12.80.22.70)
Posted on Thursday, September 25, 2003 - 3:31 pm:
Just got back from a cruise to Alaska. Quick Shuttle of Vancouver is running MC8s that they have converteded to series 50 engines with 7 (seven) speed manual transmissions. Previously they ran same MC8s with series 60 engines with a 5 speed manual. They prefer manual transmissions.
So for you guys wanting to upgrade to 4 cycle DDs in the future, it has been done and works great. 78 mph top speed. 75 with AC on.
BrianMCI96A3 (198.81.26.104)
Posted on Thursday, September 25, 2003 - 5:19 pm:
I heard somewhere you could make a silk purse from a sow's ear, too! ::::grin::: I know the 60 and 50 series DD will go in an MCI coach, the question is how much work will it take? Do you need to lengthen the coach? Will it need larger radiators? A single radiator? Will it fit on the old engine cradle?
What kind of bottom line dollars will it take to have this done? To do it yourself?
Brian
Peter Broadribb (Madbrit) (65.37.90.139)
Posted on Thursday, September 25, 2003 - 5:38 pm:
As far as I am aware, you can get the 60 in an MCI, but can't use an automatic tranny. Similar to the MC-5 only having an 8v71 with a stick or a 6v71 with an auto.
I thought there was a height problem too, which had the motor sticking thru under the bed plinth. Don't know how they do it in a seated bus, unless there is room in a MC-9.
Series 50s are a touch on the vibratory side.
Another point to ponder is that although the top speed is quoted at 78 mph, that would probably be at max rpms (2100) and 4 stroke diesels don't like being cruised at max. They much prefer to cruise at 1450 t0 1600 rpms.
Best thing to do with any big power upgrade on an MCI 8 or 9, is to install a single large side radiator and drive a fan from the crank pulley using a miter box, such as the one that used to drive the squirrel cage fans.
You can then incorporate all that area where the header tanks and fans were, into the interior.
Peter.
Jojo Colina (Du1jec) (209.75.20.72)
Posted on Thursday, September 25, 2003 - 5:45 pm:
Why use a miter box for the fan? Just use a hydraulic motor. Less hassle.
two dogs (67.30.23.15)
Posted on Thursday, September 25, 2003 - 5:48 pm:
why not elec. fans.....series 60 nice engine..wonder if they will bolt up to a spicer
Posted on Thursday, September 25, 2003 - 6:28 pm:
You already have the miterbox and hydraulics would have to be bought.
Electric fans are nowhere near powerful enough to cool that sized motor.
Peter.
FAST FRED (67.75.110.113)
Posted on Thursday, September 25, 2003 - 6:29 pm:
Mostly Electric fans are not used cause 20-hp to 30hp electric morors are HUGE!heavy & hard to power.
Doug (68.83.22.146)
Posted on Thursday, September 25, 2003 - 8:58 pm:
The proper conversion to a 4 stoke is cost prohibative.....lots of changes to make.....
two dogs (67.30.23.115)
Posted on Thursday, September 25, 2003 - 10:23 pm:
IT'S C.F.M....... NOT H.P.that cools an engine, I still say elec. fans will work...got plenty of elec. the alt. is as big as your head
BrianMCI96A3 (65.41.249.60)
Posted on Thursday, September 25, 2003 - 11:16 pm:
Dog, an alternator as big as WHO's head? Holy hand grenade Batman... I would be seriously freaked by anyone with a head as big as the 270 amp monster in my coach
Brian
madbrit (65.37.90.139)
Posted on Friday, September 26, 2003 - 12:28 am:
But it's HP that turns the blades that moves the CFM.
Peter.
two dogs (67.30.23.66)
Posted on Friday, September 26, 2003 - 3:06 am:
not if it's elec, Peter..I still think 4 elec. fans will do it,see ya' made it back Peter,sorry I was busy when you came thru Amarillo
Posted on Friday, September 26, 2003 - 7:35 am:
No probs Two Dogs, as you said, maybe next time. Unless you know of anyone coming this way who could drop that gaucho bed off, in or near Kingman?
Keep us informed how you get on with the electric fans.
Peter.
Stephen Fessenden (Sffess) (12.80.22.103)
Posted on Friday, September 26, 2003 - 2:51 pm:
Quick shuttle has done a fleet of 4 cycle conversions. When one of you is really serious about such a conversion, and willing to spend some serious money, I suggest you talk to their service department and maybe fly to Seattle, take the Quickshuttle to Vancouver and look at their MC8 engine conversions. I will not bother a mechanic trying to keep a fleet of charter buses on the road with idle dreams. I don't have an MCI. My information came from the driver who has been with them for around 20 years. I expect that the 7 speed transmission and has an overdrive to allow for the lower RPM preference of the DD Series 50.
ggo4 (208.63.185.236)
Posted on Friday, September 26, 2003 - 9:49 pm:
series 50 is a common and easy swap for MCI's like 6v92 for gmc..lots of series 50's around..just buy one and put it in all the ddec motors are easy to wire in just buy the trouble shooting manual...nothing to swapping motors just something people are scared of and so shops can stick it to you...do it your self...nothing to it
BrianMCI96A3 (65.40.144.254)
Posted on Saturday, September 27, 2003 - 5:29 am:
With all my years as a diesel mechanic, I can safely
say that ANY mechanic who can "keep a fleet of charter buses on the road with idle dreams." Is my HERO... (and I wouldn't want to bother him either)! :::grin:::
Brian
Emery Leraand (137.186.250.244)
Posted on Sunday, September 28, 2003 - 8:09 pm:
National Bus Lines out of Calgary Alberta is putting series 50 engines in MCI 8 and 9 coaches using a stock engine cradle from MCI. Apparently a run of late 9s had that engine from the factory. Now if I could find someone who could sort out the electronics on my Cat/Allison with GMC truck gauges and controls!!
Emery MCI 96
