Cory hart (Chart1)
Registered Member Username: Chart1
Post Number: 44 Registered: 1-2010 Posted From: 12.97.138.130
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, January 14, 2011 - 10:15 pm: | |
There is a cable that runs down from the throttle linkage down to the passanger side of 740 auto transmission. Can any one explain how it works and proper way to adjust. |
Ralph Peters (Ralph7)
Post Number: 168 Registered: 3-2004 Posted From: 75.214.172.214
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 15, 2011 - 1:18 am: | |
It is a kick down shifter same as older cars. |
Post Number: 1374 Registered: 12-2000 Posted From: 71.3.72.124
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 15, 2011 - 7:37 am: | |
that controls the modulator in the 740. Jack |
Post Number: 1420 Registered: 10-2006 Posted From: 66.82.162.16
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, January 15, 2011 - 8:10 am: | |
DA Book will show an angle gauge that is required to set it up. It is called the Throttle Valve adjustment. FF |
Tom Christman (Tchristman)
Post Number: 277 Registered: 1-2006 Posted From: 66.218.33.156
Rating: Votes: 1 (Vote!) | Posted on Saturday, January 15, 2011 - 11:49 am: | |
The down and dirty way is you want the lever to be fully extended when the gas pedal is floored. Easiest to have two people doing it-one at the driver's seat and one doing the adjusting. You want the lever at the maximum travel limit when the pedal is floored so the transmission is also at its' highest pressure when the engine is at maximum power to prevent excess clutch slippage. Good Luck, TomC |
Post Number: 1423 Registered: 10-2006 Posted From: 66.82.9.75
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, January 16, 2011 - 7:24 am: | |
GET DA BOOK, trannys are expensive to rebuild. FF |
