MCI 8 Detent Cable????? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » January 2011 » MCI 8 Detent Cable????? « Previous Next »
Cory hart (Chart1)
Username: Chart1
Post Number: 44
Posted From: 12.97.138.130
Posted on Friday, January 14, 2011 - 10:15 pm:
There is a cable that runs down from the throttle linkage down to the passanger side of 740 auto transmission. Can any one explain how it works and proper way to adjust.
Ralph Peters (Ralph7)
Username: Ralph7
Post Number: 168
Posted From: 75.214.172.214
Posted on Saturday, January 15, 2011 - 1:18 am:
It is a kick down shifter same as older cars.
Username: Jackconrad
Post Number: 1374
Posted From: 71.3.72.124
Posted on Saturday, January 15, 2011 - 7:37 am:
that controls the modulator in the 740. Jack
Post Number: 1420
Posted From: 66.82.162.16
Posted on Saturday, January 15, 2011 - 8:10 am:
DA Book will show an angle gauge that is required to set it up.
It is called the Throttle Valve adjustment.
FF
Tom Christman (Tchristman)
Username: Tchristman
Post Number: 277
Posted From: 66.218.33.156
Posted on Saturday, January 15, 2011 - 11:49 am:
The down and dirty way is you want the lever to be fully extended when the gas pedal is floored. Easiest to have two people doing it-one at the driver's seat and one doing the adjusting. You want the lever at the maximum travel limit when the pedal is floored so the transmission is also at its' highest pressure when the engine is at maximum power to prevent excess clutch slippage. Good Luck, TomC
Post Number: 1423
Posted From: 66.82.9.75
Posted on Sunday, January 16, 2011 - 7:24 am:
GET DA BOOK, trannys are expensive to rebuild.
FF
