Towing and Tongue Weight Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » January 2011 » Towing and Tongue Weight « Previous Next »
Username: Rjlong
Post Number: 1769
Posted From: 71.195.124.20
Posted on Monday, January 17, 2011 - 12:10 am:
All -
As a follow up to PapaTony's thread about trailer length, it's well known that a lot of coaches are not designed to pull trailers, especially ones with heavy tongue weights. GMCs in particular have been hashed over often.
Anyway, while surfing around on some auto racing forums, I ran across this little goodie. Might be a much better solution than the "Tuff-Tow" unit that's also available.
http://www.trailertoad.com/
Anybody ever seen one at a race weekend somewhere? They seem to be extremely popular in the Midwest.
Be interesting to get some feedback from owners, not typical "testimonials" you get on the seller's advertising blurb.
FWIW & HTH. . .
Username: Oonrahnjay
Post Number: 670
Posted From: 71.49.184.227
Posted on Monday, January 17, 2011 - 5:18 am:
Woo, $3200. You gotta need that bad.
Post Number: 1426
Posted From: 69.19.14.22
Posted on Monday, January 17, 2011 - 6:27 am:
And the cost of a roadside repair shop reinstalling your engine and tranny after it hits the ground?
FF
les marston (Les_marston)
Username: Les_marston
Post Number: 245
Posted From: 68.151.225.213
Posted on Monday, January 17, 2011 - 11:06 am:
I wonder if it would be legal in places that don't allow a two trailer set up.
Here in Alberta it is ok for a truck to pull a holiday trailer and have a boat trailer behind that but in B.C. this set up is not permitted.
I think it is a great idea but only if you can use it everywhere
Cory hart (Chart1)
Username: Chart1
Post Number: 47
Posted From: 66.249.37.60
Posted on Monday, January 17, 2011 - 11:10 am:
Is that considered a extra axle for toll booths.
Post Number: 1446
Posted From: 97.225.142.51
Posted on Monday, January 17, 2011 - 7:28 pm:
That's a lot of cabbage.
Plus, it looks VERY close to the rear of the vehicle...take a look at the spare tire. Tight turns....????? My guess is that is not a "hot" item for the retired bunch.
Not for me, at least :-) :-)
Ands my guess would also be that it definitely would be an added axle. That's the way I would plan my budget for toll fares....if I were going on a toll road in the North East.
I'll say "amen and Amen" to FF's note.
FWIW
Username: Rjlong
Post Number: 1770
Posted on Tuesday, January 18, 2011 - 2:01 am:
RCB -
I found a video of the Trailer Toad in motion, but now I can't find the link.
Anyway, this unit acts a bit like that retractable tag axle you see on loaded cement mixer trucks. It stays a rigid fixed length behind the tow vehicle, and the Trailer Toad's axle pivots in a similar manner to the cement mixer's.
Think of it this way - it's just like extending the overhang and body of the chassis three feet back and putting the hitch there, with a couple of 15" caster wheels to support the overhang. Does that make sense?
This thing doesn't pivot where it's plugged into the hitch receiver - that's fixed. Only the trailer pivots on the TT's ball hitch, with the TT's suspension supporting the tongue weight.
Clear as mud? Hope so!
FWIW & HTH. . .
Cement Mixer
Post Number: 1428
Posted From: 69.19.14.17
Posted on Tuesday, January 18, 2011 - 6:44 am:
About $700 at the local truck shop will find REAL dollies like Fed EX uses to haul tandem.
There heavy themselves , but if your trailer is 20,000 lbs , no problem!
FF
Username: Dmd
Post Number: 545
Posted From: 24.46.196.121
Posted on Tuesday, January 18, 2011 - 9:24 am:
i bet the booth operators wont see it but if they do you are getting charged. /there must be you tube footage of me arguing with the GW bridge "highly trained" personel somewhere! Dave's bus 3, GW bridge 4.
Ralph Peters (Ralph7)
Username: Ralph7
Post Number: 170
Posted From: 75.223.57.13
Posted on Tuesday, January 18, 2011 - 9:38 am:
Just think go up a steep driveway and no pivot, walla, 15,000lbs on that axle pop pop tires.
Username: Rjlong
Post Number: 1771
Posted on Tuesday, January 18, 2011 - 11:31 am:
Ralph -
Are you saying that the leverage induced into the Trailer Toad by the tow vehicle, when pulling into a steep driveway, would blow the TT's tires?
Or are you saying the trailer that's hitched to the TT would blow the TT's tires?
Don't you think that between the TT's suspension and the tires there'd be enough "give" to absorb that type of operation?
OTOH, do you pull into driveways so steep you drag the back end of your bus? If you know the driveway's steep enough to drag the tail, do you go for it anyway, or do you modify your approach to avoid the tail-dragging?
I would think you would do the latter, and thus would do the same if you were using a TT. Or am I missing something?
FWIW & HTH. . .
Username: Ralph7
Post Number: 171
Posted From: 75.223.82.224
Posted on Tuesday, January 18, 2011 - 12:31 pm:
RJ if this does not pivot up&down yes it will overload the hitch, and what happens when air bags go down. Both the Mci7&8 I have had had tail drag, slso many driveways to & from the older roads are short and steep. the state redid the entrance to our area not nice. I relocated my trailer hitch to the center of the bumper, now level towing, not worried about bottoming. Some railroad tracks are raised or below highway.
Post Number: 1447
Posted From: 97.215.176.64
Posted on Tuesday, January 18, 2011 - 12:56 pm:
RJ...See what you stirred up,??? :-) :-) :-)
Interesting.
Post Number: 246
Posted on Tuesday, January 18, 2011 - 1:45 pm:
So just to clarify, this dolly unit is hard fixed to the hitch on the back of the coach and has no up and down movement?
What would be wrong with having it hook up to the ball and have both up and down plus normal side to side pivot on the ball?
I don't see why this wouldn't work as well or better than having it hard fixed to the back of the coach.
I see that Greyhound uses a pindel hitch for the cargo trailers they pull behind the coach.
Are the tongue of those trailers hinged at the trailer to allow up and down movement without putting a lot of weight and bounce on the hitch?
I got to go look at one!
Username: Rjlong
Post Number: 1772
Posted on Tuesday, January 18, 2011 - 5:07 pm:
Ralph -
Stand by, more research underway. . .
Username: Dallas
Post Number: 295
Posted From: 98.20.57.250
Posted on Tuesday, January 18, 2011 - 5:22 pm:
Les,
If it has side to side movement, you couldn't back it up.... that's why they call doubles and triples, "Wiggle Wagons".
However, when I worked in the woods we had one truck and 2 axle full trailer that we hauled posts, poles and mine props on.
It was a real bugger to back up without a skidder to pull it side to side, until I had the bright idea to weld a couple of pieces of heavy channel on the tongue and on each side of the hitch of the truck, then had 2 pieces of 1" X 3" bar stock that slid between the two units.
This locked the units together and still allowed up and down movement of the pintle hitch.
No reason you couldn't use that method on any converter dolly like the one being discussed, with modifications of course.
Yes, I know you would have to install it with a pintle or ball hitch, but, hey, we can all do those mods, can't we?
Username: Ralph7
Post Number: 172
Posted From: 75.223.31.102
Votes: 2 (Vote!)
Posted on Tuesday, January 18, 2011 - 6:03 pm:
Just called the mfgr. the dolly IS HINGED an he tows a 17,000 trailer. He said he wil take a look at this site. You cannot see the hinge and he has a nasty railroad crossing that he has to cross.
Username: Dallas
Post Number: 296
Posted on Tuesday, January 18, 2011 - 6:31 pm:
I voted for you Ralph... You da Man, or Busnut, or sumpin'!
Username: Ralph7
Post Number: 173
Posted on Tuesday, January 18, 2011 - 7:07 pm:
If I knew how to get the pictures that Jok the mafgr. sent me, I would post them. I am not putter savy. He registered here so he may show it works.
Username: Dallas
Post Number: 297
Posted on Tuesday, January 18, 2011 - 7:19 pm:
Ralph, send them on to me, I can resize or host them elsewhere and show them here for you.
My email is in my profile/
Username: Ralph7
Post Number: 174
Posted From: 75.214.248.17
Posted on Wednesday, January 19, 2011 - 12:26 am:
Dal, well I tried let me know if you got it.
Username: Rjlong
Post Number: 1773
Posted on Wednesday, January 19, 2011 - 2:21 am:
Ralph -
You & I are on the same wavelength when it came to doing more research. You called, I emailed. We both heard back from Jok, the owner. (He said he would have posted here, but for the registration time-delay. . .)
Anyway, the Trailer Toad is hinged at the front, like Ralph mentioned earlier. Solid mount into tow vehicle receiver attaches to adjustable solid mounting on TT's front cross-member. Has large bushings with zerk fittings for lubrication at pivot point on each side of the cross-member, as shown below. This allows TT to move up and down vertically, in order to handle driveways, railroad tracks, valley gutters, etc. - which was what Ralph was concerned about earlier and I knew nothing about.
Here are three pictures Jok sent me, to help illustrate.
This first pic is of the pivot bushing welded into the main frame of the TT.
TT Cross-Member Pivot Bushing
The second pic is of the cross-member attached at it's pivot point to the main frame. Note the zerk fitting for lubing the bushing.
See the following post for more. . .
FWIW & HTH. . .
Username: Rjlong
Post Number: 1774
Posted on Wednesday, January 19, 2011 - 2:28 am:
All -
This last pic is of the TT hooked to a Class A stick 'n staple. You can see the rigid drawbar installed in the hitch receiver, the adjustable drawbar brackets to level the TT to the tow vehicle, the cross member pivot points (gold-colored bolts), The red handled gizmo is one of the two locking pins used for backing up.
TT Installed
All in all, seems like a well-built unit that addresses a lot of the issues we busnuts face when towing a heavy trailer. A little pricey? Maybe, but FF hit the nail on the head when you compare it to the cost of repairing a failed engine cradle. The stick 'n staple crowd have it even worse, because heavy trailer tongue loads not only bend the frame behind the axle, but it also tends to pull apart the fiberglass box, too! (My neighbor works at an RV repair facility - tells very interesting stories of how the stick 'n staple rigs come apart after towing!)
Lots of kudos on several of the auto racing forums - the guys who use them all seem to swear by them. It seems like it's only the folk who don't own one, have never seen one, or have never used one, well, they're the gearheads bashing the product. Ah, well, such is life!
FWIW & HTH. . .
Username: Dmd
Post Number: 546
Posted on Wednesday, January 19, 2011 - 7:18 am:
That explains the m/c guy who wrote the testemonial and did the test article. The legnth of his hitch under the slide in camper was over 4'.No up or down wieght its just a draw bar with this unit. Nice posting guys
Username: Dallas
Post Number: 298
Posted on Wednesday, January 19, 2011 - 7:42 am:
No Ralph, I didn't get your email.
JC Alacoque (Jc_alacoque)
Username: Jc_alacoque
Post Number: 99
Posted From: 207.34.166.7
Posted on Wednesday, January 19, 2011 - 10:19 am:
Now that I see that it is rigidly attached to the tow vehicle, as opposed to hitched by a ball, it might be legal in BC, where two trailers are not allowed.
JC
Username: Ralph7
Post Number: 176
Posted From: 75.223.239.4
Posted on Wednesday, January 19, 2011 - 10:26 am:
Sorry but RJ has the same pictures, by the way that is the mfger's stick&staple, he said his 17,000lb trailer when hooked the TT can be tiped up&down by hand.
