Gary Crider (66.84.75.4)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, October 04, 2003 - 5:05 pm: | |
I keep loosing my prime 83 MCI9 6v92, I took the check valve out and cleaned it. I would like to know about how much pressure the flap has it doesnt seem like much. Thanks Gary |
two dogs (67.30.23.112)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, October 04, 2003 - 5:18 pm: | |
replace the check valve |
BrianMCI96A3 (65.41.249.117)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, October 04, 2003 - 6:24 pm: | |
ditto: replace the check valve |
Peter E (Sdibaja) (64.165.10.27)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, October 04, 2003 - 6:28 pm: | |
Gary, I have a simular problem... See thread "Fuel drains back (4905)" I have a 45 degree fitting on my bulhead that the checkvalve mounts to. That makes the run back from the primary filter downhill. I think I will give the 45 fitting a bit of a twist so that the valve runs about 15 degrees UpHill, rather than 45 degrees DownHill... I think I have a long enough fuel line to do that. Perhaps you could try the same thing with yours Will report back in a few days, I just dropped her off in the storage yard 30 miles away My check valve is in good shape... Peter E |
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, October 04, 2003 - 10:34 pm: | |
second thought... the pipe running downhill puts the weight of the fuel on the flaper valve... pushing it Closed. the setup I have should be optimal. there must be another leak or a siphon on the return line. Peter E |
