Bus won't start Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2003 » October 2003 » Bus won't start « Previous Next »
Gary C. (66.84.75.4)
Votes: 2 (Vote!)
Posted on Sunday, October 05, 2003 - 6:17 pm:
I have a 83 MCI9 with a 6v92,I have tried to start it 3 times since I bought it in May. It will turn over but wont start, I put a 24v priming pump in the system and ran it until fuel came back to the tank in the return line. The bus will start on starting fluid but wont continue to run. I try to start it about 5 or 6 times at 30 second intervals, is there something I am missing.
Thanks
Gary
Tony (216.207.2.191)
Posted on Sunday, October 05, 2003 - 6:24 pm:
It seems highly unlikely that all the cylinders went bad at the same time so I would see If my fuel pump is working
Stan (216.95.238.97)
Posted on Sunday, October 05, 2003 - 6:45 pm:
It sounds like your fuel rack is closed. Check the stop cylinder and lever on the top of the governor.
two dogs (67.30.23.59)
Posted on Sunday, October 05, 2003 - 8:46 pm:
99% of the time...if a diesel won't run....it's out of fuel
mel 4104 (208.181.100.111)
Posted on Sunday, October 05, 2003 - 8:53 pm:
good answer stan the fuel rack is more than likely frozen shutoff and you are getting no fuel. but you are killing your motor BIG time using starting fluid, even in small amounts, there is no way that i would use starting fluid no my bus engine. if it is cold apply some form of heat to the engine,even a 2-300 watt lite bulb under the pan or a block heater is great to warm it up but never starting fliud.it has to be a fuel problem so make sure you have fuel in the tank and that it is getting to the rack as it is very unlikely that all the injectors failed at the same time. mel 4104
Larry (208.18.102.29)
Posted on Sunday, October 05, 2003 - 10:58 pm:
Was it shutdown with emergency stop switch? If so reset it at engine.
Cullen (205.188.209.8)
Posted on Monday, October 06, 2003 - 12:42 am:
If it will start on starting fluid, then die, you need to check your blower shaft. If your blower (not your turbo) is not turning, you are not getting any air to mix with your fuel.
FAST FRED (67.75.106.32)
Posted on Monday, October 06, 2003 - 5:14 am:
"there is no way that i would use starting fluid no my bus engine."
The use of Ether as an alternate fuel, below freezing , when there is no block heater or electric is considered normal.
There is no harm in a tiny shot (1 second) into the ether cup , thats why its there!
(When below freezing only!!)
The use of Ether to prime a warm engine can be disastrous .
Far easier to use WD40 (kerosene) and not worry about broken stuff.
bus\dog (68.35.161.40)
Posted on Monday, October 06, 2003 - 6:31 pm:
Modern starting fluid is a proper mixture of volatile, highly flamable liquids and lubricants and when used properly will cause no harm to a detroit diesel engine. If used on a hot engine detonation coul;d result however most diesels can absorb detonation of that sort. large quantities of starting fluid could cause damage
akrom (198.81.26.104)
Posted on Tuesday, October 07, 2003 - 1:00 am:
Good grade of startin fluid is fer sniffin only...use cheap stuff fer buss and truks. akrom
Al Gore (205.208.227.29)
Posted on Tuesday, October 07, 2003 - 9:37 am:
I invented starting fluid
Phil Dumpster (12.230.214.167)
Posted on Tuesday, October 07, 2003 - 10:37 am:
There is no emergency shutdown on the series 92.
If your blower shafts aren't turning when cranking, then your engine gets no air and without air no fuel will burn. Ether isn't a magical substance that will burn without air.
mel 4104 (208.181.100.71)
Posted on Tuesday, October 07, 2003 - 11:20 am:
when i worked as a hd meck. on construction we hhad 27 guys in the shop and the rule was that if one of us or an operator was found with a san of starting fluid you were fired on the spot. you were there to find and fix the reason why it would not start not add to the ruin of an engine. as to a little bit you can get a lot of fluid out of a can in one second. also most people go to the back of th eir bus . squirt it bown with fluid and then go to the front and try to start it. this way you get all that fluid on the first few cylinders and this is what causes oil washed off thecyl. walls a massive explosion that cacses broken rings and bent rods. but then again use it if you want, there are a lot of mech looking for work, how i will not. not time no money. mel 4104.
Posted on Tuesday, October 07, 2003 - 11:57 am:
We used to use starting fluid to seat tubeless tires on the rim in the field.
Anybody know how this is done?
Gary
BrianMCI96A3 (198.81.26.104)
Posted on Tuesday, October 07, 2003 - 2:43 pm:
Gary, that would be with a BOOM!
Brian
Posted on Tuesday, October 07, 2003 - 2:48 pm:
Well, that is the fun part anyway....
Gary
Brian96A3 (198.81.26.104)
Posted on Tuesday, October 07, 2003 - 3:02 pm:
Gary, I talked to the Tire guy... and I added to the Tires for a Silversides string.
Brian
jim mci-9 (209.240.198.60)
Posted on Tuesday, October 07, 2003 - 6:58 pm:
we would spray a little in under the bead that was knocked off.. then throw a match.... it wouls seat... if there was grease on the rim....
Gary Crider (66.84.75.4)
Posted on Tuesday, October 07, 2003 - 8:07 pm:
Bus started, I put the ether away for good.The fuel shut off on top of govenor was closed, when I pulled the lever it retracted.I cranked engine over and white smoke started to come out of the exhaust and it startad on 2nd try without ether.The engine ran for a couple of minutes and shut down,Ichecked sight gauge on coolant tank and it was low. I guess that the sensor was not in the coolant and it shut the fuel off.
Thanks I,m learning
Gary C.
