Peter Broadribb (Madbrit) (216.67.207.110)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 19, 2003 - 9:32 pm: | |
Guys, How much space is there between your ceiling panels and the roof? What thickness of which type of insulation or R-value do you use? How high is your ceiling and how much room above YOUR head do you have in the coach? What is the overall height of the coach? Thanks. Peter. |
David Anderson (168.215.176.199)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 19, 2003 - 10:40 pm: | |
3.5" roof to ceiling 1.5" sprayed in foam. I think its R value = 6 Ceiling height about 6'8" coach height is 12'6" to top of Coleman low profile rooftop AC's 1985 Eagle with 7" roof raise David Anderson |
Don Ripley (206.149.192.230)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 19, 2003 - 10:46 pm: | |
I raised my roof 8" and ended up with 79" head height.I have a flat ceiling with about 3" in the center. My outside height is 12'5" with roof airs.My coach is an 85 Prevost. |
mark (65.40.225.193)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 19, 2003 - 11:54 pm: | |
'75 Gillig 636D 6'4" ceiling height 2" ceiling to roof 1 1/2" fiberglass batt insulation (R4?) Not much! Outside height - not sure! I'm only about 5'9" - plenty of headroom for me and my wife! Mark 75 gillig 636D |
Rodger in WA (64.70.24.54)
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, October 25, 2003 - 10:56 am: | |
'76 Prevost Champ w/no roof raise. About 1" (maybe a little more) of sprayed foam. R? Suspended naugahyde headliner with an inch or so of air space between headiner and foam. Note: Heating and cooling is not a problem in extreme heat or cold. Headroom's about 6' 3 1/2", less under the AC. Exterior height is 10 1/2 feet plus roof ACs, for a total of about 11 1/2'. |
