Battery basics, huh? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2001 » April 2001 » Battery basics, huh? « Previous Next »
dougthebonifiedbusnut (24.147.157.103)
Posted on Wednesday, April 04, 2001 - 11:02 pm:
hey fred i just bought a big old battery charger when i saw the picture of it i thought it had a built in volt meter when i got it, it did not anyway i read your battery basics piece and was left with a whole lot of questions the charger just has a timer and five settings 6v, 12v low, 12v med 12high and start i have four group 31 750 cca batts and i just want to keep them charged they are maint free so i feel them to make sure they dont get even warm how do i tell if they are fully charged and can i over charged them with them without knowing it i put the charger on 12v med at about 10 amps for about an hour is a volt meter the way to check their state of chargeas always thank you very much
FAST FRED (209.26.87.42)
Posted on Thursday, April 05, 2001 - 7:37 am:
WHAT You probably have is an old "constant amps" style charger. These are great at restoring deep cycle batts , as the strong charge 10A , at the finish brings the batts back to 100%.
Unfortunatly they work best with batts that can be slightly overcharged and have water put back .
IF your batts are sealed , they are prob starting batts and better left to the engine alt, as that has a very slow finish.
Your unit would br great for restoring sulphated deep cycle batts , with a good pulser to break down the sulphated plates.
