Laryn Christley (Barn_owl)
Post Number: 688 Registered: 10-2006 Posted From: 71.254.38.213
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 24, 2011 - 12:26 am: | |
Found this on Ebay - JAKE BRAKE SET- DETROIT DIESEL 8V-71 Everything - Buy now $200!! JAKE BRAKE SET- DETROIT DIESEL 8V-71 Everything - Bus We have here a jake brake set for a DETROIT DIESEL 8V-71. Will fit the 92 also but there is a difference in the Valve Bridges. So you woud need to get the 92 valve Bridges. I have a complete 8V-71 that I am parting out so if there is anything else you need email! These came off a running engine but they are sold as is http://cgi.ebay.com/ebaymotors/JAKE-BRAKE-SET-DETROIT-DIESEL-8V-71-Everything-Bus-_W0QQcmdZViewItemQQhashZitem41571e682eQQitemZ280634484782QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories (Message edited by barn owl on February 24, 2011) |
Post Number: 549 Registered: 1-2009 Posted From: 72.211.128.245
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 24, 2011 - 12:55 pm: | |
may be wrong but... aren't special Jake heads needed to convert an 8-71...? Buswarrior? |
Post Number: 388 Registered: 7-2004 Posted From: 98.20.51.73
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 24, 2011 - 1:24 pm: | |
nope, for a 71 series, other than the 2-71, and the two valve, they will work. If you have a 92 series, you'll need them to say 71-92A, otherwise you'll put a couple hundred bucks into a set of bridges for the 92. BTW, there are also Jakes available for the 2 valve 71's, but they are hard to find. At one time I knew how to change a standard 4 valve 71 Jake to 2 valve use. I haven't done it for years, and won't even try on my own 2 valve engine. |
Post Number: 1044 Registered: 8-2006 Posted From: 74.33.43.204
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 24, 2011 - 8:16 pm: | |
Dallas,71 bridges won't work on a 92 series the valve spacing is wider on a 92 series you will need 92 bridges good luck |
Post Number: 390 Registered: 7-2004 Posted From: 98.20.51.73
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 24, 2011 - 8:24 pm: | |
Yup, your right Clifford, I stated it wrong, Sorry. |
Post Number: 2033 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 24, 2011 - 8:58 pm: | |
Wouldn't yopu need to know what voltage solenoids they are? 12 or 24 volt. |
Post Number: 689 Registered: 10-2006 Posted From: 71.254.38.213
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, February 24, 2011 - 11:12 pm: | |
They were 12v. |
