Exhaust out the top on a 4104? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2003 » November 2003 » Exhaust out the top on a 4104? « Previous Next »
Eric Plourde (12.221.168.155)
Posted on Thursday, November 20, 2003 - 6:32 pm:
Wondering while I am rebuilding the back skin on my 4104 if I should just run the exhaust out the roof to protect my toad or just out the side.
Feel the need to relate this:
Cleaned the first two of four air elements today in my bus. The bottom oil bath pans weighed about 10 lbs. I scraped an inch of red Utah dust out of the bottom. Poor engine with only 2 clean elements runs like a different machine.
Back to the exhaust question. Thanks for any help.
Eric
Jay Gerlick (152.163.252.163)
Posted on Thursday, November 20, 2003 - 7:05 pm:
Hi Eric,
I don't know how the 4104 is put together but on our MCI 9 it was fairly easy as we were redoing the back cap also. I ran a 6" Exhaust pipe from engine compartment thru the roof and this was the chase for my 5" chrome exhaust pipe. Little bit of flex and some nice stainless clamps and 1- 90` bend up and i was set. The chase inside was covered with "the wet blanket", then 1200` fiberglass, then thin stainless w/straps. At the top and bottom of the chase I drilled three 1/4" holes then welded nuts over them. I then used stinless cap screws to center the 5" chrome pipe in the 6" chase. Worked great!!
jim mci-9 (209.240.205.60)
Posted on Thursday, November 20, 2003 - 7:11 pm:
what engine is in your mci-9 ??.... i like the idea....i have a 8v71 in mine...thanks...jim
Tom Caffrey (Pvcces) (65.74.64.127)
Posted on Friday, November 21, 2003 - 12:53 am:
Eric, I thought that the 4104s used three air cleaners. Does yours really have four?
Thanks!
Suncatcher
Posted on Friday, November 21, 2003 - 10:02 am:
IT has four pans sticking out around the blower but one of them is slightly different. I am going to get to it in a min. but a visual inspection shows 4.
I really need to pull the rear window and the cover over the air channel and clean all that out. In due time.
Thanks for the info Jay. I guess I need to decide if I want to metal up the window or cap the entire thing first. I like the lines of the steel factory cap.
Eric
4106 on the open road
3 days till I put down another 1500 miles.
Henry of CJ (207.14.166.17)
Posted on Friday, November 21, 2003 - 5:27 pm:
Just thinking that if you plan on redoing the exhaust, then being able to see any smoke from the driver's seat may be a good idea. May save you a ticket in Commiefornia. (California)
Posted on Friday, November 21, 2003 - 5:31 pm:
That's Kalifornia Comrade.
mndean (67.30.118.37)
Posted on Sunday, November 23, 2003 - 1:06 pm:
"Commiefornia"? "Kalifornia Comrade"? I think we've found the genesis of the new Algonquin Round Table here.
