Tag axle chains for mci-9 Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2003 » December 2003 » Tag axle chains for mci-9 « Previous Next »
jim mci-9 (209.240.205.60)
Posted on Monday, December 15, 2003 - 8:43 pm:
anybody got the chains that hold the tag axles up???... i need to keep my tag axles up off the ground for a while.... i need to find out what they look like, how long, how heavy???etc....
Joel Lanstra (Joel) (64.142.48.67)
Posted on Monday, December 15, 2003 - 9:05 pm:
Jim,
A 3/8's Grade 8 chain has a working load capacity of 7100#'s on a straight pull. Use it on a 45 degree pull and the capacity drops to 5000#'s.
This means that if you can chain straigt up and down, a single 3/8's chain on each side will allow a combined 14200# working load. If you have to chain on an angle, the working load of the chain is reduced by the angle. Therefore you may need 2 3/8" or a 1/2" chain.
Joel
Earl-8-Ky (207.162.163.19)
Posted on Monday, December 15, 2003 - 10:24 pm:
A piece of 3/8 chain will do just fine. Just don't put any air to your tag axle.
BrianMCI96A3 (69.34.171.174)
Posted on Monday, December 15, 2003 - 10:55 pm:
Hey Jim, I have those chains on a shelf in the battery bay on my 96A3, as I recall
they are three links long and they might be 7/16".
I'll try to go out in the AM and measure link diameter and chain length size for you.
Brian
Posted on Tuesday, December 16, 2003 - 4:06 am:
thanks brian..... i remember seeing something like that in a friends bus... the links were odd-sized.... they have to be. in order to fit over the hooks....i wonder if a piece of flat bar steel with slots cut in each end would work aslo... maybe 1/2" stock????
Posted on Tuesday, December 16, 2003 - 10:20 am:
Jim, I'm glad I went out to look...
Froze my a**, but got you this:
Length of chain is 11.5"
First link is 3" long
every other link is 2 3/8" long
each link is 7/16 diameter
I believe there are 5 regular links and the one long one, but I forgot to write that down, defintely more than the three links I mentioned before.
It is not grade 8 chain, and I work with grade 8 chain all the time.
Brian
ED-NJ (67.85.224.113)
Posted on Tuesday, December 16, 2003 - 4:50 pm:
1,tagchain
, Funny stoty, When I bought the bus and was looking throught every thing I bought. I saw these chains and said to my self who cut up the tire chains. So I threw them in the garage on their way to the garbage.(what good are 11.5" chains?). Then I took a visit to Luke's, It was then I saw all those tags held up by little short chains . When I got home I put those chains back on the self in the battery box.
Posted on Tuesday, December 16, 2003 - 5:07 pm:
"1,tagchain
