How many miles should a 6V92 be good ... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2003 » December 2003 » How many miles should a 6V92 be good for? « Previous Next »
bruceknee (12.76.101.175)
Posted on Sunday, December 28, 2003 - 12:40 pm:
The 102A3 that I bought last month as a non-runner has a 6V92 which was inframed 185k ago.
It started blowing oil out of the left bank.
It has been sitting for a year. Charged the batteries and fired it up yesterday. It started right up, had good oil pressure. The mechanic seems to think that it has a cracked piston by the tapping sound that it is making. His and my thoughts are: get into the left side, if the wrist pin bushings are not sloppy and the bearings are tight, replace the bad piston/liner and walk the dog.
I appreciate your feedback. There seems to be a lot of good info. that passes through this site.
Thanks, Bruce
Geoff (Geoff) (66.238.120.26)
Posted on Sunday, December 28, 2003 - 12:58 pm:
At 185K the engine has a lot of life left in it. Pulling the left head and repairing the failure would be the way to go. Hopefully the valves didn't get bent if a piston broke. Incidently, it is common practice to replace a "jug" if something happens in a Detroit. A lot of times a valve will drop into the clyinder and do exactly what you describe. (Let us know!)
TWO DOGS (63.185.97.109)
Posted on Sunday, December 28, 2003 - 9:40 pm:
nobody ever answered your question....I'd expect 5 to 7 hundred thousand out of a GOOD rebuld...'if' it had a rebuild 185 thousand ago...it SHOULD have documents...lots of people 'tell' you it was rebuilt...I think I would start off with an oil sample sent in after a good warm up
BrianMCI96A3 (65.160.208.21)
Posted on Sunday, December 28, 2003 - 9:44 pm:
I agree with Geoff, lots of life left, make sure you replace everything that's not 100%.
Brian
TWO DOGS (63.185.64.150)
Posted on Monday, December 29, 2003 - 8:40 am:
if you have ground-up engine parts in your oil...be kinda silly to work on the left bank..
