Iver (Mciv)
Registered Member Username: Mciv
Post Number: 53 Registered: 11-2006 Posted From: 70.69.131.252
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, April 01, 2011 - 3:03 am: | |
My coach has 2 split-system a/c in the spare tire compartment in our MC-9. I might have to remove one when I change the steering box to integral. Unfortunately I have to remove the refrigerant lines from the lower unit and electrical in order to get it out. If I can't save the refrigerant, what is involved to get the system recharged? Thanks, Iver. |
Post Number: 1082 Registered: 8-2006 Posted From: 74.33.61.190
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, April 01, 2011 - 7:53 am: | |
Iver, they are not hard they have the taps and a sight glass getting the r-22 is the problem but they are touchy about the charge it has to be right on or they will not start in 100+ degrees.When you get the unit out it has a chart for the charge on the unit and be extra careful with electric valve it costs a small fortune if you need manuals I have some extras I may even have a drier for one good luck (Message edited by luvrbus on April 01, 2011) (Message edited by luvrbus on April 01, 2011) |
George M. Todd (George_todd)
Post Number: 1219 Registered: 8-2006 Posted From: 99.62.5.248
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, April 01, 2011 - 9:22 pm: | |
Iver, I would call a local commercial air conditioning company and tell them what you want. They will have a recovery machine to take your refrigerant out, IF your system doesn't have valves to "pump down" the charge into the condenser. If it does have valves, they will know what to do, and you won't waste any refrigerant. After you relocate, they can evacuate and properly recharge your system. G |
Post Number: 363 Registered: 10-2006 Posted From: 75.221.39.129
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, April 02, 2011 - 10:26 pm: | |
Cruseair has a pdf online I have it somewhere. It gives you the high and low side pressures relitive to the ambiant temp in 10 degree increments, a bar graff. Get it right or you will not be a happy camper. If you have another onboard that is a good chiller have the tech hook the gauges into that one and then duplicate the reading on the one your working on. They are finicky but work very well when corrrect |
