Detroit 8-71 Engine Rotation - Please... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » January 2004 » Detroit 8-71 Engine Rotation - Please Help!! « Previous Next »
Gabe (209.165.45.107)
Posted on Saturday, January 03, 2004 - 8:03 pm:
I've an MCI-7 with a tired engine (8v71 natural) and a freshly rebuilt 8v71T out of a sidewinder. I have perused the archives for hours trying to find answers, but can't seem to find what I'm looking for. Could someone who has done it before tell me what is entailed and what parts I'll need to convert the LH (?) sidewinder engine over to RH (?) rotation for my T powered MCI? I read one post where someone claimed that the oil holes in the cranks for the rod bearings were in different places with regard to the rotation of the crank. This shouldn't be true, nor should it make any difference, as the bearing is riding on a cushion of oil all the time. Any help from someone who has had experience?
Posted on Saturday, January 03, 2004 - 8:08 pm:
Also, I keep seeing references to "the book"......is there a repair manual out there that is better than others?
jim mci-9 (209.240.205.60)
Posted on Saturday, January 03, 2004 - 8:21 pm:
Detroit diesel makes their own service manual.... you can find them on ebay.... but by the time you pay shipping... its prolly just as cheap to get 1 from your friendly neighborhood detroit dealer.... i paid $57 for a manual on a 671....from DD... i also just bought an old (1950) 671 manual on ebay for $8.50...."da book" is slang for the service manual for your particular coach....
Posted on Saturday, January 03, 2004 - 8:24 pm:
and to answer your question about changing roation, the engine will have to be dissasembled...gear tarin changed on the back... cams changed....oil pump changed for correct rotation.... cranks used to be different but now they have the sae part number....ask geoff.....
GAbe (209.165.45.107)
Posted on Saturday, January 03, 2004 - 8:47 pm:
Thanks Jim,
Does the gear train have to be changed from one end of the engine to the other, or just reconfigured on that end? Should I use cams out of the old 8-71 naturally aspirated, or are the turbo cams specific?
Posted on Saturday, January 03, 2004 - 8:58 pm:
i know the idler has to be moved over to the other side.... i'm not sure about the cams.....where's geoff when we need him??????
Geoff (Geoff) (66.238.120.26)
Posted on Saturday, January 03, 2004 - 9:29 pm:
Here I am! I was watching Geraldo for the "Inside Scoop". Okay, switching roatations on an engine is not easy-- you are practically rebuilding it to get what you need. You have to change the cams and half the gear train, change the oil pump, and switch everything else to match your oil engine. Plus you are changing from a Natural to a Turbo so you have additional problems to deal with that I am not going to get into here. Personally, I would just rebuild your old engine and sell the the LH engine-- or maybe just use the heads off the turbo engine to save a few bucks.
